Questions on installing return type fuel system
First off thanks in advance for your help.
I have twin Walbros and plan on going with a return type system 8an feed with 6an return.
1st. What do you have to do to install the lines on the top of the fuel bucket/lid?
2nd How do you route your lines and where do you bring them into the engine compartment.
I know just about nothing about hoses and fittings so no answer is to simple.
Looking to buy all the pieces (kit) within the next week or so, just need to get as much info as possible and advice before I buy. It's not a cheap purchase and want to make sure I get as much info as possible and not wish I would have gone a different route.
I have had a few pm's back in forth with a vendor but would like to hear what anyone else has to say or reccomendations.
http://www.vetteworksonline.com/cata...roducts_id=216
Check Vettworks. They are just down the road from you in Auburn. That is where I got my LS1 module. The blue fittings are adapters of the slip on to AN fittings.
If you have the factory hard lines you do not need this modification.
These are more links to installing the LS1 fuel pump module.
http://forums.h-body.org/viewtopic.p...+tank&start=30
Scroll down to last post
http://www.pro-touring.com/showthrea...2nd+Gen+(74-77
This link has links to other good info.
Kleeborp the Moderator™
I guess I see how it might be helpful to some people, but the original poster wants to eliminate the regulator in the tank and move it up front - the parts you are mentioning will NOT help him accomplish what he wants to do. That's where the disconnect is here.
The stock regulator is mounted in the fuel pump module. Held in with the silver spring clip.
pry the the spring clip off and remove the regulator.
Mount an adjustable regulator on the fuel rail and connect to the return line.
Thanks, yes I understand you control the fp by a regulator up front, I just didn't know if you removed the internal regulator without replacing it with something if the system would still pump fuel or just leak it out where the regulator was located.
Here's a picture of the parts you need to plug the t-fitting where the stock return line goes back to the tank (back by the fuel filter).
The correct parts you need to plug that T-block are:
Russel Part # 648070 (14mm x 1.5 O-ring to -6AN)
-6AN Cap (I used Summit Racing part number SUM-220640N)
![](http://i305.photobucket.com/albums/nn227/meentss02/FuelSystem026.jpg)
