WHAT PUMP should i run?!?!
Old Feb 8, 2011 | 05:44 PM
LSxWS.6's Avatar
Default WHAT PUMP should i run?!?!
well im going to go with siemens flowmatched 60lb injectors with my N/A h/c/i 500whp set up. now what brand/kind of pump should i run? do i even NEED too? id like one compatible for e85. i can get a BOSCH 044 from a friend locally for a little under 200 but have heard they arent e85 friendly. im not 100% sure if and when ill run e85 but i want to buy the right pump once so it can take what ill throw at it. i hear walbro arent the best...but what do you all think?
bosch 044
racetronix/walbro http://www.racetronix.biz/customkititems.asp?kc=RFPK-001&eq=
any suggestions are welcomed
do these pumps just drop intank and replace stock pumps or will i need wiring, filters and so on. thanks i know ZERO about fuel upgrades
Old Feb 8, 2011 | 06:33 PM
LSxWS.6's Avatar
anyone?!?!
Old Feb 8, 2011 | 06:37 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You threw out a lot of variables to consider.
The single Racetronix w/ Hotwire is good for at least 550rwhp on gas. These are direct fit kits & are a great way to go. I have these in stock.
On E85 you will probably need more pump. There are a few options, but none are a direct fit. I offer a dual kit that will easily support your needs. Feel free to give me a call to discuss your options.
Old Feb 8, 2011 | 06:51 PM
LSxWS.6's Avatar
great thanks alot, are you selling the racetronix cheaper then they are? hahah and lets forget about the e85, how do you feel about the bosch 044? and do you kno if thats a pain to put in?
Old Feb 8, 2011 | 07:17 PM
LS1TECH Sponsor
Typically my price is within a dollar or 2 of Racetronix.
My customers get my free tech support...
As for the 044, it does not exactly fall in place & due to your lack of experience in fuel systems, I would suggest the tried & true Racetronix kit for the least amount of trouble.
Old Feb 8, 2011 | 07:21 PM
LSxWS.6's Avatar
alright great, the racetronix to be clear does not handle e85 correct?
Old Feb 8, 2011 | 08:59 PM
LS1TECH Sponsor
Actually no GSS series Walbro pumps are E85 rated, but I have had great luck with the Racetronix/Walbro pumps with E85 for many years.
Old Feb 8, 2011 | 09:07 PM
DopeFedLSX's Avatar
bosch o44 is good. you have to buy a screw on sock and a fitting to go to barb for the feed hose.
Old Feb 9, 2011 | 08:11 AM
LSxWS.6's Avatar
would you recommend the 044 or racetronix? seeing as the racetronix is a driect drop in with all fittings for 208.99 and the 044 is around 200.00 then buying the fittings?
Old Feb 9, 2011 | 08:13 AM
LSxWS.6's Avatar
great, i would prob have2 run 2 racetronix/walbro for e85 if im around 500-550 whp on just the one racetronix pump correct?
Old Feb 9, 2011 | 10:05 AM
LS1RedZ's Avatar
Lonnies double pumper kits are VERY nice! It looks like stock when you get it back. Ive got one in my car right now.
Old Feb 9, 2011 | 10:09 AM
LSxWS.6's Avatar
yea they do look very nice but a little pricey for me for now
