E85 subsidies. Whats everyone's thought?
http://www.startribune.com/business/136838948.html
I'm still in the collecting parts stage and my motor setup depends on the fuel that I'm going to use. I was going to run around 11:1 for my boosted block on the corn. Now if corn prices increase to race gas prices, or worse gets dropped entirely, what is everyone that's running corn going to do?
I attached a picture of my GTO's piston after running E85 for three thousand miles. The piston is untouched other than a rag to soak up the anti-freeze that accumulated after pulling the heads.
![](https://ls1tech.com/forums/attachments/fueling-injection/361811d1341269611-e85-subsidies-whats-everyone-s-thought-e85-clean.jpg)
The picture below is the cylinder to the left (#3) three thousand miles earlier. The carbon build-up was untouched by human hands. The E85 cleaned the piston!
![](https://ls1tech.com/forums/attachments/fueling-injection/361812d1341270606-e85-subsidies-whats-everyone-s-thought-93-octane.jpg)
After seeing the difference I understood why they call regular fuels "high carbon."
I believe there was a thread on e85performance.net about a year ago where there was government talk of a replacement fuel similar to methanol for use as an alternative. But, without doing a lot of searching I cannot say exactly.
Maybe some ground up and boiled Zombies would do the trick!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
To the OP I say go for it because you'll just be paying a little more if anything for the ethanol and I see benefits for you. In North Texas I find quite often at least and even down around here sometimes
