Super victor injector question
Old Feb 26, 2014 | 08:33 PM
rich's Avatar
Default Super victor injector question
Looking at 04 5.3 flex fuel dephi injectors should be 36# I believe. with they fit with the 3638 rails?
Old Feb 27, 2014 | 12:01 AM
Blown06's Avatar
8 Second Truck Club
If those are the truck injectors they probably won't fit. Super Victor and Victor Jr. rails use the longer ls1 style injectors.
Old Feb 27, 2014 | 10:12 PM
rich's Avatar
I was told 04 Tahoe 5.3 flex fuel. All I can find for info is design III Bosch style? is what they say fits. I Googled Design III Bosch and it looks like the ones I'm getting. We will see. if not, I have seen adapters.
Thanks
Old Feb 28, 2014 | 12:08 AM
Blown06's Avatar
8 Second Truck Club
I'm pretty much 100% sure those won't work.
Old Feb 28, 2014 | 06:45 AM
rich's Avatar
http://m.ebay.com/itm/171069336427 need something like these to make it work?
Old Feb 28, 2014 | 12:21 PM
george g's Avatar
All you need is different o-rings for the bottom and make a set of brackets to mount the rails to the intake.I'm using ls3 injecters on a vic. jr. just needed ls3 to ls1 o-rings and made shorter mounting brackets.Try injector dynamics for the o-rings and home depot for some L brackets $40 tops for everything.
Old Feb 28, 2014 | 08:06 PM
rich's Avatar
Thanks I was thinking that too. but wasn't sure on the clearance of everything till it is here.
Old Feb 28, 2014 | 08:10 PM
rich's Avatar
I see in your signature you are running a 4150 throttle body. I bought the intake with the 4150 to 4500 adapter and the 1600cfm 4500 throttle body real cheap. I am going to try it. It is pretty big for 346 cuin.
