Dual In-tank pumps with Racetronix components
#81
We are VERY busy this time of year so it may take a few days to get back to customers. If you are in a rush to get parts or answers we have many dealers who support this forum that are willing to help over the phone during business hours.
Lonnie's Performance is our DP specialist who can provide complete tested assemblies.
Please note that the DP items we recently started offering to the general public were originally intended for dealer installation only. In order to help the DIY crowd, we have made some of these DP items available to the general public. We emphasize that customers must have advanced technical skills in order to install them properly. Our harnesses are mostly PnP which makes them intuitive to install but customers must have a solid grasp of wiring and fuel system assembly. These components do not come with instructions. We do offer limited support on our forum 24/7 however basic questions which indicate very limited customer knowledge will prompt our technical support staff to advise said customer to seek qualified installation services. If you have never worked on your fuel system and do not feel comfortable with wiring components, we recommend you contact a Racetronix dealer who can install them for you.
Thank you.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
#82
WIRING:
1 x UDPH-004
1 x IDPH-FLT1
1 x DP-ITWH-FLT1
1 x HIH-001
1 x HPS-4 or HPS-7
PUMP ASSEMBLY:
1 x DPA-510 or DPA680
1 x FFT-175
2 x OCLMP13.3
2 x OCLMP12.8
1 x UDPH-004
1 x IDPH-FLT1
1 x DP-ITWH-FLT1
1 x HIH-001
1 x HPS-4 or HPS-7
PUMP ASSEMBLY:
1 x FFT-175
2 x OCLMP13.3
2 x OCLMP12.8
__________________
>WEB SITE<
>WEB SITE<
#83
#85
I just put one in a Gto yesterday
Have to do a decent amount of cutting but it will fit
Used bulkhead fittings on the sender itself for feed and return
Very simple with a little dremel work
#86
Racetronix, any idea of the life of the walbro pumps?
i put the hotwire and single gss340 pump in my car back in 2004 which is 11 years ago, but the car maybe has 5000 miles on it in those 11 years.![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Any idea how much life this pump has left? I am wonding if i do a DPA-510 kit do i need both pumps or just one new pump since the current pump is old in years but not in miles driven.
Thoughts?
Thoughts?
#87
Thoughts?
Thoughts?
It is impossible to tell how much life it has left.
The F99 FPA-001 is not compatible with a DP system.
__________________
>WEB SITE<
>WEB SITE<
#89
WIRING:
1 x UDPH-004
1 x IDPH-FLT1
1 x DP-ITWH-FLT1
1 x HIH-001
1 x HPS-4 or HPS-7
PUMP ASSEMBLY:
1 x FFT-175
2 x OCLMP13.3
2 x OCLMP12.8
is DP-ITWH-FLT1 needed for my 1999 camaro ls1 with full bolt ons, HC and 15 lbs approx 700 whp? i only ask because it doesnt appear on the order list at checkout on Racetronix website but it does appear on the list above.
1 x UDPH-004
1 x IDPH-FLT1
1 x DP-ITWH-FLT1
1 x HIH-001
1 x HPS-4 or HPS-7
PUMP ASSEMBLY:
1 x FFT-175
2 x OCLMP13.3
2 x OCLMP12.8
#90
That's for an LT1 car. Use the matrix in the link below and you will be supplied with everything needed.
http://www.racetronix.biz/customkiti...DIYDPK-F99&eq=
#91
I have a 2008 avalanche. Currently it has a 408 ci making 500 horsepower. I'm adding a twin turbo set up. The injectors are 160 lb. Which dual fuel pump assemblies do you recommend?
