what is the trick to remove the harness from the fuel injector
I have a LS3 and need to remove the fuel rail and replace an injector on my LS-3. What is the trick to remove the harness from the injector? Thanks
I googled and found this for a 6.0; hopefully it's the same-
"Pull and slide the grey tab slider then press the tab on the on the injector connector inward, it will come off easy"
Got it, pull the gray plastic up and squeezed, thanks. By the way here is my LS build; https://www.corvetteforum.com/forums...o-touring.html
Be very cautious when removing the injector from the fuel rail so you do not damage the O-rings, if you have a damaged O-ring you will possibly get a leaking injector.
