Monitoring Fuel Rail Pressure
New (1st) ls swap build
What are most people doing to monitor the fuel pressure. Just inline somewhere on the supply side ?
Like
Right now looking at this setup for fuel ......... 6.0 stock engine - custom aluminium fuel tank due to offset 8.8 rearend.
Fuel Pump => https://www.summitracing.com/parts/tnk-pa-4
Fuel Pressure REG/Filter => https://www.summitracing.com/parts/cmb-03-0263
Fuel Sender => https://www.summitracing.com/parts/cin-sn35t9
Decent fuel line kit with -6AN 3/8 fuel line /..... [TBD].
1) What gauge for Fuel Pressure
2) what fittings for supply/return at the fuel rail
3) Anything else ?
thanks
Like
3) Anything else ?
thanks
thanks
Like this Joe ?
https://www.summitracing.com/parts/r...gaAhnwEALw_wcB
Any recommendations on good priced/value fuel line kit ?
I hate to revive this thread but I can't seem to figure out which attachment I need for the schrader valve. The auto meter 3227 kit came with an adapter but it doesn't fit? What size do I need to accomplish this?
The 3 foot hose that comes with the kit will connect to the threads, but I don't want to use that line if I don't have to.
You're looking for a -4AN female to 1/8 NPT fitting.
Glowshift makes a cheap one, that's what I use and it worked perfect, good price too. Vibrant also makes one, a little more expensive.
https://www.amazon.com/GlowShift-Adapter-Pressure-Sensors-Pontiac/dp/B00GS8E3WY/ref=sr_1_10?dchild=1&keywords=ls1+fuel+rail+adapter&qid=1594784193&sr=8-10
