Replacing Corvette style filter/regulator with an adjustable fpr.
If I swap in an adjustable, will it need to be vacuum referenced, although the Vette style isn't? I'd hate to run a vacuum hose all the way to the rear of the car.
What adjustable fpr and filter would you recommend to replace the c5? MagaFuel, Fuelabs, Weldon?
I use this one:
https://www.summitracing.com/parts/aei-13109/overview/
It was originally plumbed in for a turbo setup, but I left it there after turbo was taken off. Mine is plumbed (actually replaces) the factory T. I still use factory style replacement fuel filters. Zero issues with steady, consistent fuel pressure. Simply unplugged and removed the vacuum hose from when it was turbocharged
I use this one:
https://ls1tech.com/forums/fueling-i...l#post20184015
https://aeromotiveinc.com/wp-content...0109-0revH.pdf
