Dual hellcat 525's
https://ls1tech.com/forums/fueling-injection/1530926-my-plastic-bucket-mod-dual-walbro-pumps.html
https://ls1tech.com/forums/forced-in...omplete-2.html
https://ls1tech.com/forums/fueling-i...k-cheap-5.html
https://ls1tech.com/forums/fueling-injection/1345276-dual-walbro-wiring-install.html
So I wanted to generate a parts list that is specific for a 99-02 F-body for running these pumps in tank based on the knowledge accumulated over the years. Everything from fittings to electrical. There are several companies that make wiring harnesses to accommodate dual pumps. You can even make your own. There are several types of submersible in-tank wiring harnesses for various pumps, but the use of dual Hellcat 525 pumps will require the dual in-tank wiring harness described as "ITWH, DP, MP150/280 > 2 x DCSS" The 450 walbro pumps use that same harness, while racetronix pumps tend to use ITWH, DP, MP150/280 > 2 x GSS. There's 2 different part numbers for each, depending on if you want 8" in length or 12" in length. An easy plug and play solution is to go with the racetronix DPWK-022 kit and select the DCSS in tank harness. You may want to see if a 2 PSI pressure switch can be used. There are other options from other vendors. Now you can make your own in tank harness to a custom length and purchase the individual parts contained in the kit separately, but you'd only be saving about $30. I'd rather deal with the extra wire length in the bucket than have to make my own harness.
DPWK-022 comes with:
UDP HD Fuel Pump Wiring Harness (MP280) UDPH-005
HIH-001 - Hobbs interface harness 72" DPK
HPS-? - Hobbs Pressure Switch, ?PSI, SPST M/P280S (select PSI based on application.)
IDPH-F99-HD - Intermediate Double Pump Harness Kit F99 (note that this part on it's own currently doesn't have the option to switch out the GSS harness for DCSS)
Walbro makes a stand alone kit for the 450 or the 525 part number 400-1168 which includes the filter, single pump harness, submersible hose, clamps, etc but it would be a waste to purchase 2 of those since the wire quality is not as thick as what you get in the racetronix harness. Plus you'd have to modify 2 harnesses into one, so it makes more sense to simply purchase the filters and shorter length 10mm submersible PTFE fuel hose separately rather that buy two of the 400-1168.
Below is a schematic for the system being described, but note you can use your factory feed line as the return line. I figured I'd just run an 8AN return line an future proof the system. Injectors and fuel rail not included. Again, this is only one option and there are several ways to go about this.
Our FLK-F99 is all you need for lines, fittings, filter, reg, rails etc. One source, one brand, one knowledgeable source of support.
https://www.racetronix.biz/customkit...asp?kc=flk-f99
We offer a DPC and bulkhead for coupling the pumps:
https://www.racetronix.biz/product.asp?ic=dpc-jm8b38
Harness solution for F99
UDPH-005
IDPH-F99HD
DP-ITWH-042
HIH-001
HPS-7 =>
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Do the fuel rails in the FLK-F99 work with the holley sniper 822102-1 intake? What O ring size do the fuel rails in FLK-F99 accept? I like the fact that these are 3/4 fuel rails. The ones holley recommends are 850002 and those are only 3/8"
An plans for a Dual Pump Coupler, -10ANF » 2 x 3/8" Barb in the future?
I see that your kit is 8AN / 6AN. I was told to run 10AN / 8AN to future proof it.
Deadhead config is junk!
Our rails take std 14mm LS1/LS6 injectors.
Rail mounting is same as factory. We are pretty sure some customers have used them with the Sniper intake.
-8 Teflon fittings and hose flow enough to support 1500HP so why would you require -10?
>WEB SITE<
>WEB SITE<
https://docs.rs-online.com/ffc8/0900766b812ba8a5.pdf
100% agree with this. I'm glad I'm not the only person who thinks this. Having the regulator AFTER the rails ensures both rails are getting the most possible flow/volume from the tank.
We normally run the feed line to a Y at the engine, then to the front of both rails, the out of the back of the rails we go into the regulator then obviously back to the tank. We run the feed in the front, so under a hard launch, the fuel is going the same direction.
This configuration is simple and provides the most stable pressure possible. A y-block is not required unless HP starts approaching 1500. If the PTFE fitting nipples are used to measure the length of hose it is possible to be accurate within 1/4" which enables use of the 90° -8 ORB fittings for the crossover line. The FILTER-1212B in our kit c/w a billet bracket so it is easy to mount it at the back of the car. The 10-micron SS magnetic element flows more than enough fuel for 2 x F90000285 Walbro (525) pumps. All these parts are included in our FLK-F99 kit.
>WEB SITE<
Your kit is actually cheaper than what I priced out separately. I'm assuming the fuel rails are compatible with the BTR IMA-03 intake? Do you offer a pump that is equivalent to the F90000285 Walbro (525) pump?
https://www.racetronix.biz/product.asp?ic=f90000285
>WEB SITE<
Great for manufacturer's cost reduction, terrible for performance apps.
>WEB SITE<
