Nitro-Methane (CH3NO2)
I will be discussing high-percentage/ concentration Nitro-Methane here, not to be confused with low-percentage/ concentration Nitro-Methane (as used in RC Cars).
This Thread is regarding the Fuel used in Drag Racing and formerly experimented with in the early days of Space Shuttle Fuels (deemed too dangerous).
It is one of the most explosive organic chemical compounds, carries it's own Oxygen Source, and behaves very similarly to Dynamite (Nitro-Glycerin).
Dynamite also has the same ignition characteristics as Nitro-Methane. Dynamite is not to be confused with TNT (Trinitrotoluene).
There are other compounds that can be combined with Nitro-Methane to make it more explosive.
I will absolutely NOT be giving out any information on that topic.
Nitro-Methane is difficult to ignite via a flame or heat source...
Instead it is very easily ignited by a shock source (like Dynamite).
Poor a tiny amount in a frying-pan and hit it with a hammer, it will blow up in your face.
Poor a large amount in a frying-pan and hit it with a hammer, it will blow explode the pan and kill you.
Engines burning high concentration Nitro-Methane must have all fuel and residue evacuated from the engine prior to starting the engine.
OTHERWISE a minuscule amount of left behind Nitro-Methane will ignite as any cylinder comes up on compression...
OFTEN EXPLODING THE ENGINE!
This fuel is used to power the most powerful vehicles and crafts in racing.
It can be used (with the proper education) as a power-adder in automotive engines as well.
It will often triple the output of an engine running on gasoline.
To date it is the safest Fuel that can be used...
That can also have the needed fuel volume to make 15,000 HP (with current safety rules) and remain stoichiometric.
It was NOTORIOUSLY mixed with Nitro-Methane in the 1960s NHRA Drag Racing.
It almost always produced extreme complete Engine Explosions on Engine start-up.
Nearly always causing near fatal or fatal injuries to anyone standing near the Vehicle/ Starting-Line.
Avoid at all costs!!!
Anyone else that brings up Hydrazine...
Kindly please:
Nearly always causing near fatal or fatal injuries to anyone standing near the Vehicle/ Starting-Line".
We ran T/f in the 60's with this exact combo.
Had not a single explosion. Did a few stock iron block 392's in, tho.
To add to the mystery, we were known to use some Propylene oxide, organic compound with the molecular formula CH3CHCH2O, too.
Ya, it was dangerous to use. Some of the others used "weird love potions", too.
Last use was at the World Series in Cordova, Il... Circa 1965. NHRA put the kibosh on it really fast.
And no, I didn't STFU
As i already said, yes It almost always produced extreme complete Engine Explosions on Engine start-up.
I had been running TA/D with the optional Normally Aspirated Fuel (Nitro-Methane) combo Dragster until 2019.
I am a Third Generation Semi-Pro Driver in Division 1 (NED)...
With Family that ran in AA/G, A/A, AA/A, AA/FA, TA/FC, TA/D, AF/D, AND T/F.
You don't like my Threads of useless nonsense?
Thats too bad.
No one is forcing you to read my Threads...
Yet you still are reading them.
Like for instance all the NA guys that spend retarded amounts of money with forged rods, crank, pistons. Aftermarket heads and $2k intakes just to get their **** railed by some guy with a stock 5.3 and $500 turbo. I’ve seen more people have problems with spinning bearings on “built” motors compared to the sbe guys.
Larger amounts can be used with an EFI configuration similar to what is needed for Methanol use.
I hear it mixes well with methanol. Also heard stories of old sprint cars ch3ating by throwing a bit into their tanks. But anyhoo, wonder if the little amount of gas on E85 will make it so it does or doesn't mix
But! It sure makes the starting line guys go bonkers!
My alky fe rail was a great "attention getter" with < a pint to 5 gallons.
Strait meth, thru a "Laguna leanout" injection. Tuning was a piece of cake.
Correct.
People add a small amount of it to their meth injection tanks for that extra power bump.
