Racetronix 32# best injectors for LS1?
I plan to make ~425rwhp from my H/C LS1 and want to keep my injector duty cycle well below 90% on the stock fuel pump and pressure. For this reason I would like upgrade from my stock 28.8# to something larger. The SVO 30# seem to be the most popular but I found this very disturbing old post:
I am now looking at the Delphi 32# from Racetronix. Does anyone have feedback on these? Are they a better match to the GM computer and fuel rail than the SVO 30#? Are there good mail-order tunes for the 32#? Obviously they flow enough for the power my engine will make.
Thanks
The 30# SVO injectors (that I installed a year ago) are much longer from the "O" ring back into the fuel rail than a stock unit, so much so that the Ford injectors are rubbing against the metal on the backside of the rail. This is a VERY bad thing and could prevent fuel from getting to the injector and/or cause it to overheat and lock. The shorter GM injectors fit properly and would not be a problem.
So if you are running Ford injectors you might have a problem. I had an SVO 30# injector fail and take a piston with it - while road racing, and running at high speeds for a sustained period. Probably would never have been a problem in around town driving.
Thanks
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
According to my calculations, for a 420 rwhp engine, Delphi 36# will get you closer to 80% duty cycle, which is a very, very sweet spot for fuel injectors....easy to tune, and no idle problems.
Edit: Remember, GM stockers and aftermarket injectors are rated at different pressures (3 and 4 bar) so for example: delphi/lucas 30# at 3 bar is equvalent to 35# at 4 bar. Industry standard gets rated at 3 bar....
[QUOTE=AdamSS]According to my calculations, for a 420 rwhp engine, Delphi 36# will get you closer to 80% duty cycle, which is a very, very sweet spot for fuel injectors....easy to tune, and no idle problems.
QUOTE]
Those numbers sound great to me, but isn't the next step up from 32# in Lucas/Delphi a 37#? Not trying to split hairs but is there a 36# injector?
QUOTE]
I know Accel and CPR make nice 36# injectors. I've used them both. Bosch has 36's also.
For what your'e after, I'd go with a set of 36's. That'll keep you around 80% now and you'll have some room to grow for future mods.
Stock L67 motor out of the Grand Prix GTP has 36# injectors. you can pick up some cheap over on the www.clubgp.com board
You're right...next step ia 37# and you should always increment UP to the closest match...get 37# - I know i will...I'll be doing H/C swap myself soon, and 37# Delphi is what I'll get....
LS1TECH Sponsor
The 37's are on sale too...???
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
so would this pump be good enough to flow what I need on a 415HP H/C setup on 28lb'ers along with maybe an NX MAF plate wet kit spraying around 150 shot?
Thought I would need injectors but sounds like the pump is my next bottleneck.
How hard is it to install one of these? I mean I did the H/C myself (with issues) but for some reason working with fuel give me the creeps.
LS1TECH Sponsor
The fuel pump comes with instructions on how to install it into the module. The removal of the tank is something that is covered in the G.M. manual.
__________________
>WEB SITE<
>WEB SITE<
ok.. so it sounds pretty easy. Will I be good to 650 or so with this pump? If I replace it to run a wet kit on top of the H/C I don't want to have to mess with it again.
I've been reading for the last hour but found mixed results mostly due to regulator issues? Do I need one of those as well for this type of shot?
LS1TECH Sponsor
__________________
>WEB SITE<
>WEB SITE<
These sound like a great option! Are they dimensionally idential to the stock 28.8# LS1 injectors?
