Straight tubing to hose fittings
What type of fittings do people usually use when connecting straight 3/8" fuel line to steel braided hose line. I have the earls hose end (female) at the end of my hose, but I'm having trouble finding -6an male tube ends. Hydraulic and Air conditioning places around my area are clueless. Any help would be apriciated.
RUS639200 -Anodized Fuel Line Adapter- * -6 Female Swivel To 3/8" Hard Line
http://www.paceparts.com/index.asp?P...&ProdID=122984
That's what I used at the fuel rails and fuel tank.
Originally Posted by White.Lightning
yea.
do it the way guys have done it for decades before the "hardline adapters" came along..
slip a tube nut on, and flare the hardline.. then it directly connects to the fitting you already have on the hose.
edit: be sure to use the correct flare tool for the connection. not a standard double flare tool.
The hose you have to put together your self with straight hose ends use the Russell fitting mentioned I have them for $8.50 then a -6 male to male union to -6 straight hose end.
Nate
Nate
A -6an tube nut?
Originally Posted by MrDude_1
yea.
yea.
Originally Posted by ROCNDAV
Yeah, a buddy of mine bought one of those cheapy flare tools from harbor freight and machined the flare angles from 45 to 37? degrees
OK, got a pic but where do I get just this fitting and can I intall it myself with semi-normal tools? I have a 45 and 37 degree flare tool if that helps. And this also, is a female tubing end, it won't go straight into a hose end without an adapter will it?
