what is the highest octane I can run in an ls1
I met someone tonight that told me there is gas station that sells 100 octane. Can I run this on my ls1 or does it need to be diluted to 98 or 97? Can u run it in a lt1?
no real need for higher octane. unless your high on compression or spraying its alil added insurance. and all fuels have different specific gravities just like the differences in octanes.. check the motor octane and rated octane when choosing a fuel for you application.. but again like others have also said unless you have a ls1 or lt1 with comp higher than 12:1 with timing in it.. no need for it on stock motors or even mild combos
well if you have a stock ls1 and use prostock 118 to 120 leaded you will lose a good but of hp v/s say using 100 unleaded. the higher the octane the slower the burn and flash point.
