stock pcm 96# injectors
Old 07-22-2010, 07:25 PM
  #81
BLK02WS6's Avatar
Anyone have good injector table data (voltage adj, minimum pw, small pulse adjust) for the 96#ers with the Versafueler? I'm totally shooting in the dark on these and could use some help...
Thanks!
Old 07-23-2010, 09:49 AM
  #82
350SS's Avatar
There's a tune in the efilive tune repository under modified tunes that uses 96# injectors... not sure if the values are actually correct or not.
http://www.holdencrazy.com/EFILive/modifiedTunes.php
Old 07-23-2010, 06:27 PM
  #83
BLK02WS6's Avatar
Thanks - I looked at it... some stuff in the tune looks a little iffy, so I don't know if I can believe the injector tables or not. Might try them though - idle is my biggest problem... at least that's easy to find out quick.
Old 07-24-2010, 05:51 PM
  #84
Turbomike88's Avatar
This may sound stupid but here it goes how do you tune with a stock pcm can you hook a laptop to it ??? i am new to EFI , i have had about 50 prostreet and drag cars and all thith carbs , i am building an lq4/lq9 6.0 motor with a turbo and almost have said to hell with the efi and went to a blow thru carb , but i really want to do the efi on the car , any help would b great , i did read this thread and i am still in outerspace on this stuff
I was looking at the mega sqirt MS3X but i am clueless on this to
Old 07-24-2010, 07:54 PM
  #85
BLK02WS6's Avatar
Yes, you hook a laptop to it. I saw your other thread in the tuning section - I'll reply over there...
