stock pcm 96# injectors
has anyone run 96# injectors...stockpcm...impedance converter AT LS1 FUEL PRESSURE? i am wondering if they will idle ok. I have the 97/98 vetterails and cant dial down fp. 83# injectors are more than enuff but i found a god deal on some 96# injectors
I have those now on my car, but havnt started it up yet, have the harlan impedance converter and will be tuning with HPT 1bar RTT setup to get the idle straight then after thats set copy the tables over to the 3 bar (no RTT) setup.
once i get my cable back from my friend ill probably start it up and start messing with it. provided its not raining or snowing bad.
im not to worried about the idle, i think they will do ok.
just hope the 96's will be big enough
also still waiting on getting my tranny in, guy is taking for ever getting that RMVB and brake on it, good thing he's doing it for free or id be upset by now. :0
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I run 96s on the stock PCM with the versafueller converter box.
If you have a 346 like me the idle will be rich (11.0 AFR) which sucks, but I deal with it. Ive reduced my injector pulsewidths the maximum amount I can before I start seeing adverse effects, still wasn't enough. But at any cruise RPM AFR is normal ~14
only idle can I not get lean enough.
I imagine if I had more displacement it woudln't be an issue.
Originally Posted by koji777
I'm running the 96's (versafuler setup) on my 408.... running 3bar sd tune..... I too run rich at idle!!!
What did your setup put down? and whats the Duty cycle of the injectors at those numbers?
What do u guys use for a base Fuel Pressure number?
I am also on HPT 3 bar 96 lb on 408. Idle is fine at 14.7 (base pressure of 50 psi) but my throttle transitions are problematic, when i decel/off throttle=rich, then back on throttle=lean. WOT is ok . Makes 6 spd car not fun. I am trying some resistors instead of the versafueler box and I am thinking these may be my problem. I have tuned numerous 4 cyl 600+ HP FWD cars on 96 lb injectors and have seen 25-32 MPG on the 4 cyl cars and a great 15 AFR idle/cruise at base pressures of 55 psi on some. I am now at 4-5 MPG on the 408 lol. I definitely need more tuning time and probably a versafueler.
if anyone has figured out the secret to running the 96# low inp/versafueler package properly I would love to hear what they did. I hate thinking that I need to change the setup to get a more driveable car.
Thinking maybe should have went efi live or BS3. Ill give it another few weeks of tuning effort then its off with the HPT. Maybe one with a few credits for sale if i dont get the throttle transition figured out. Hows the EFI stuff working??
Only positive I could see with EFI live is all parameters/tables are real time. Down side is EFI cost a bit more. With the throttle response problem I am having it would be nice to have some transient fueling tables in real time since there is not really a explanation of what table does what. So it is, make a big change, burn, start car, drive, repeat process with the transient fueling tables to see what does what.
Originally Posted by foff667
considering both programs have near identical tables/parameters you can change I really can't see how...in the end its still up to the user to change the correct ones to the correct range.
And can you assist the tuner if necessary?
Im moving forward with 83 or 96's and have yet to decide on HP or EFI /RR combo.
Feel free to PM me part #s for HPT.
Slowhawk, thats all I needed to hear...it can be done. Your the man.. thanks.
