question on injectors.
Old Mar 21, 2007 | 08:18 PM
ou812/z28's Avatar
Default question on injectors.
what is the highest low imp injectors made...... need 80+.....
Old Mar 21, 2007 | 08:32 PM
andereck's Avatar
I think you may mean high impedence or sometimes referred to as high-z as low impedence injectors go up to at least 160 #/hr.
Try racetronix.
Old Mar 22, 2007 | 05:32 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...html?item=1066
RC Engineering 75lb shown here. Bob
Old Mar 22, 2007 | 05:58 AM
ou812/z28's Avatar
my bad i mean high imp...
Old Mar 22, 2007 | 07:25 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The best and highest flowing hi-z injector is our Siemens L107FM:
http://www.racetronix.com/L107FM.html
These injectors will delivery apx. 73lb/hr at LS1 fuel pressure of 58PSI.
RC does have a hi-z 75 but they are very sluggish in performance and pose some tuning issues. You can make some serious HP on the L107FM's and they are much faster and can be run at higher pressures than the RC 75's. If you do require more fuel than the L107FM's can deliver you should consider low-z injectors along with an injector driver box.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 22, 2007 | 07:38 AM
MIGHTYMOUSE's Avatar
the L107 is rated up to 83# at 85psi on the mototron website. they are the nicest injectors you will find.
Old Mar 22, 2007 | 12:09 PM
DeltaT's Avatar
I have the RCEng 75# Hi-z injectors and have had no problems with tuning, idle or driveability. Plug, tune n' play.
Jim
Old Mar 22, 2007 | 03:28 PM
abustiffy's Avatar
Jim
Same here on both ls1 and lt1
Old Mar 22, 2007 | 04:37 PM
Racetronix's Avatar
LS1TECH Sponsor
We have some dealers which have had tuning issues with them. Obviously it depends on your application and what you may consider acceptable for drivability and idle A/F. There is no comparison between the L107FM and the RC75's.
We have some customers running a base pressure of 72.5PSI/500KPa with the L107's which nets a static flow of apx. 81lb/hr. Siemens tests L107 injectors to 87PSI/600KPa.
Given the price premium for the RC75's and what it costs for a low-z injector w/driver most opt for the latter. Yes, PnP is nice but there are some tradeoffs.
There are some new hi-tech hi-flow hi-z injectors under development right now but there are no scheduled release dates.
__________________
>WEB SITE<
Old Mar 22, 2007 | 05:11 PM
kcmags's Avatar
Anyone have any experiance with FAST units ????
Old Mar 22, 2007 | 05:38 PM
Racetronix's Avatar
LS1TECH Sponsor
FAST distributes an array of re-boxed product which is no different from what is available on the market now. They carry injectors from Siemens, Bosch and Delphi.
http://www.fuelairspark.com/Products...lInjectors.asp
__________________
>WEB SITE<
