Any of you guys runing Custom Fuel Rails?
Old 02-08-2003, 03:13 AM
RobZ's Avatar
Default Any of you guys runing Custom Fuel Rails?
Or modified the stock ls1 Fuel rail.Looking to upgrade the stock fuel system soon.Any Pics?
Old 02-08-2003, 01:35 PM
MIGHTYMOUSE's Avatar
Default Re: Any of you guys runing Custom Fuel Rails?
try a search
this is my fuel system
http://community.webshots.com/album/29211724vvFXlMScRb
Old 02-09-2003, 07:53 PM
SILVER BULLET's Avatar
I know Speed Inc. sells fuel rails, you could always give them a call
Dave
Old 02-09-2003, 08:21 PM
LS1 BU's Avatar
I'm running the speed inc. rails also. They are nice pieces.
Old 02-09-2003, 10:58 PM
DONAIMIAN's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1 BU:
<strong> I'm running the speed inc. rails also. They are nice pieces. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How are they hooked up. Did you leave all the otehr stock lines in place, or did you do everything from tank to injectors. Also are you running an external fuel pump. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 02-09-2003, 11:39 PM
I did everything from dry sump tank to injectors with a 420 LPH pump. It is being done right now.
Old 02-10-2003, 07:38 AM
GeorgeC's Avatar
I have modified stock fuel rails on my car. There are -6AN fittings brazed on to the ends of each rail, which are now used for the inlets. The pulse damper is gutted, and the stock inlet line also has a -6AN fitting brazed on to it and is now the return line which goes to my Aeromotive regulator then back to the tank.
I don't think the stock lines are an actual restriction until you're putting down some really big HP numbers. If you aren't in to modding stuff yourself, the Speed Inc. rails are really nice.
Old 02-10-2003, 10:32 AM
Super Moderator
Reckless's Avatar
Smae thing as George....stock rails with crossover removed and -6AN fittings silver soldered on all ends:
www.cofba.org/users/reckless/fuel.html
Old 02-10-2003, 01:07 PM
RobZ's Avatar
Great I'll just modify my stock ones. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
