Belt driven fuel pump
This way the electric pump can prime the system and does not restrict flow to the mechanical pump once said pump starts to outflow the electric.
Just an idea.
..just getting started..
that being said. i think the gearing would be wrong having to run the pump at around half the crank speed would require a pulley with twice the circumference of the stock damper.
So what are you thinking for mounting the pump to the bracket. For example the Aeromotive pump is probably the most common I would think, which uses a slip collar design.
Let me know if I'm getting to far ahead.
https://picasaweb.google.com/1144453...CMnwuImn2uejfg
I know David designed this for the aeromotive pump but you may be able to get it to work with a cable drive setup as well. My biggest concern with running a belt drive pump with my car is if its going to have a big enough downward slope from the tank to the pump to gravity feed it.
These are the only pictures I have with the pump in place. The fuel pump is a buddies and I had to return it.
[IMG]http://i129.photobucket.com/albums/p229/longdcrew/20140627_13
635_zps816b4c23.jpg[/IMG]
The only issue I had was the brackets touched the bottom of the pump, all I did was grab some spacers from ACE Hardware and it cleared. My waterpump isnt a FACTORY pump but is pretty much the same thing.
Thanks a lot, thats what I wanted to see. So just so I'm clear you stuck some spacers between the block and Daves bracket to move it out further from crank centerline? Right?
