Magnafuel pump blowing/melting fuses, fuel tank, lines, pump getting hot.
So about a month or so ago I had a problem one day where I blew fuses on my magnafuel 750 pump. It ended up being my dead battery causing that problem. So its been fine for awhile now, running a 25A fuse. But today I drove across town to a buddies to weld some stuff up and I get close to home and car dies going about 20 MPH. No fuel pump. I replace the fuse, it looks melted and blown. Its black and very obviously melted. I get another 1/4 mile and it blows again. One more time (I carry alot of fuses lol) and I get home (another 1/4 mile maybe) and it blows that fuse the second I get in the garage. I check the fuel pump and its hot. I can keep my hand on it but its hot. But heres whats interesting: EVERYTHING was hot, I mean the fuel lines, the metal fuel cell, everything. I think my fuel is getting hot, the pump is getting hot, and pulling high amperage. I had about 1/4 tank.
I've noticed that my fuel mileage really sucks, even for a 750 RWHP car. I don't beat on it much, never WOT on the street for more than a second cause it just spins anyway. But I'm getting REALLY bad mileage. Maybe I'm getting the fuel hot and boiling it out? My sheet metal fuel cell is vented. Is this possible? I don't have any fuel leaks, but I get maybe 4 or 5 MPG in town.
Would a fuel cooler help enough? This is weird, I thought the Magnafuel pumps were able to handle this. It was about 90 degrees here today, if it matters.
I'm bummed, I hate being scared to drive my car for fear of getting stranded.
ok we both our setups about the same time.... can i see how you vented your tank. i believe several members did not like how i did mine but i have NO issues what so ever with my setup. cooling temps or fuel problems. im thinking your vented tank is plugged and now is making your setup fail.
btw ive driven 200+ miles during a gtg napa wine cruise here in CA in one day and had no issues
That is one hell of a pump for 750 hp you are moving alot of unnecessary fuel that is a 2000hp pump. What size lines are you running with it? A cooler will help considerably but I would step down the pump. There 4302 will feed 750-800rwhp and there 4301 will feed 1200rwhp.
Nate
Nate
Nate , That goes completely against what your shop told me when I ordered my 4303 pump from you guys for my turbo setup........
You guys said this pump could cruise all day long on the freeway (which has nothing to do with 750hp or 1500hp) with this pump and never have problems with overheating the pump or fuel..
Now your suggesting a downgrade to this guy because the pump cant handle street useage??
That doesnt add up to having melted wires/relays and overheating problems on the pump itself......
FWIW, Magnafuel tech support thinks my pump is fucked up, so its getting sent back. I was also told this thing should be able to cruise all day, in fact I know people who drive the **** out of theirs with no problems so hopefully Magnafuel can fix mine to be reliable.
Nate
