Are LS3 injectors the same as LS7 injectors?
Old 06-08-2008, 11:40 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Default Are LS3 injectors the same as LS7 injectors?
Title pretty much says it all... I came across a good deal on some LS3 injectors and the guy said they are the same thing as the LS7's. If so, what is the flow rate for the LS3 & LS7 injectors?
Old 06-08-2008, 12:18 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i know ls7's are around 40-42lbs at 58psi
Old 06-08-2008, 12:48 PM
ChevyChad's Avatar
Yeah, I found out that the LS3's are 41.74# @ 58psi, so that pretty much confirms it then.
Thanks
Old 06-08-2008, 04:52 PM
Dynojet Fan
VH5150's Avatar
Thanks
where did u find that out??
Old 06-08-2008, 06:17 PM
ChevyChad's Avatar
corvetteforum search...
Old 06-08-2008, 07:47 PM
Dynojet Fan
VH5150's Avatar
thanks... you wouldent happen to have the thread link???
Old 06-08-2008, 11:43 PM
1966goat's Avatar
Yeah they also share the same #
Old 06-09-2008, 10:33 AM
ChevyChad's Avatar
I'll see if i can find it again...
Old 06-09-2008, 11:33 AM
Nasty N8's Avatar
They also are only about 1" tall and use a different connector then your car. Just so you know.
Nate
Old 06-09-2008, 11:54 AM
ChevyChad's Avatar
This is for my 69 corvette with an LS7 shortblock, L92 heads and L76 intake
Old 06-10-2008, 12:22 PM
Nasty N8's Avatar
OK just wanted to make yo aware they are micro.
Nate
Quick Reply: Are LS3 injectors the same as LS7 injectors?
