Are 60lb injectors good enough for 700RWHP?
On a procharger D1 or F1 will this injector size be good for 700RWHP? I have twin walbros , high flow fuel rails , and upgraded fuel lines will this be enough or do I need 72lbs? I made 560RWHP on 50lbs almost maxing them out on low comp 408 stroker on a P1.
Those injectors are 72 pounders at 58 psi. They will be more than enough with a good boost ref regulator set at no less than 58 psi base.
