High flow fuel rails.
Old Sep 1, 2003 | 11:54 PM
Dragaholic's Avatar
9 Second Club NA
Default High flow fuel rails.
High flow...
1. do they flow better than stock ones?
2. What kind of modifications are required to use them?
3. Do they hurt you in any way?
4. Are there any drawbacks? Do they require tuning?
5. Ive seen a couple of sponser sell them, are they all made from the same company?
6. If not, is there one better than one another or all of them, or are they all the same?
7. What kind of benefits/advantages/pros/etc. does this item offer?
8. Is there any hp gain?
9. Are they worth the money?
10. Whats the main purpose or purposes for these?
Sorry for all the questions, but just wanted to get a little info on them. Thanks
Old Sep 2, 2003 | 10:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: High flow fuel rails.
I have the SS Racing billet fuel rails from Speed Inc.
They flow more than stock.
Old Sep 2, 2003 | 12:40 PM
Dragaholic's Avatar
9 Second Club NA
11. What does better flowing fuel rails equal?
12. What advantages/disadvantages does it have over stock rails?
Old Sep 2, 2003 | 01:57 PM
mkoch1's Avatar
Larger fuel rails mean you can push more fuel to the injectors. If your stock fuel rails supply enough fuel for your set up adding larger rails will not give any performance improment. You only need them if the rails are the bottle neck in your fuel system
mark
Old Sep 2, 2003 | 02:00 PM
LS1Tech Co-Founder
I hope to make 700-800 crank hp.
Old Sep 2, 2003 | 05:04 PM
Dragaholic's Avatar
9 Second Club NA
13. How much power does the stock fuel rails support?
14. Do you necessarily have to be running a ton of power to use these?
15. Even if you dont need them, will they benefit you in any way?
16. Do they have any affect on gas mileage?
Thanks
Old Sep 3, 2003 | 01:21 AM
CAT3's Avatar
Restricted User
I thought heard liek 600 for the stock rails, but not sure.
14. No
15.Yes, they will look cool and be there begging youtot ake it to the next level.
16. only if you need the extra fuel, then of course, if more for show, then no.
Old Sep 3, 2003 | 06:47 AM
Dragaholic's Avatar
9 Second Club NA
I thought I heard like 600 for the stock rails, but not sure.
600 what? Dont have very much knowledge in this section, sorry.
Old Sep 3, 2003 | 10:15 AM
mkoch1's Avatar
my guess is he means 600 rwhp (rear wheel horse power)
mark
Old Sep 3, 2003 | 11:57 AM
Dragaholic's Avatar
9 Second Club NA
600 rwhp seems a bit high to me! I dont even know if N/A car could pull those kind of numbers. If anything, its fwhp/bhp, but even that is probably low to mid 500 rwhp. I know that my car may not necassrily need them, but if its an upgrade to consider and looks good, then why not right?
Old Sep 3, 2003 | 01:28 PM
CAT3's Avatar
Restricted User
Yes I meant fwhp...Like I said though I am not sure. Search in this section, I know i read it last year, when resourceing nitrous and everything else. Of course, PSJ, Colonel, 9Ball or others normally have this type of info embedded in there memory.
Old Sep 8, 2003 | 04:06 PM
jimmyblue's Avatar
Moderator
Just looking at the plumbing, I'd say you wouldn't
need bigger rails until you have a bigger / better
fuel pump, forward line and regulation. The 10 feet
of unregulated forward run matters a lot more than
the last foot of rail, drop-wise.
Now, if I saw someone selling a kit that included
purty rails, an engine-mounted bypass regulator,
a >= 3/8" prebent forward feed and the fittings
to convert the existing feed to a return, bypass
the rear regulator and make it all look good and
make steady pressure at the rails a reality, that
would cause me to part with cash money.
