Shortening a 10 bolt?
I'm looking at getting my rear end narrowed. It is a stock 10 bolt and I need to shorten it 4-5" on each side. Couple of questions:
1. Is this possible?
2. If so, where can I get the axels?
3. Not being concerned with wheel clearance, will narrowing that much have an affect on the LCA bracket, if so, what can be done?
I'm looking at a very deep dish wheel setup so that is the reasoning behind it. Also, if we can, lets keep this on topic, not saying whether I need to switch to a 12 bolt/9" or not. I'm fine w/the 10 bolt for now, it cut a 1.44 60' without flinching 100% so I'm not worried about it.
Thanks for any input!
1)Anything is possible, weather its worth it is up to you.
2)Moser or Strange should be able to supply any length you need.
3)Your wheels couldnt move in much, I know my car is a stock 10 bolt and has 315s on the rear and I have about 2" of clearence between the tire and LCA. If you narrow the rear your LCA brackets need to stay in the same place or you will need to move the mounts on your chassis. LCAs need to be straight.
You knew it was coming and I gotta say it...why pay that much for shorter axles, narrow the housing, move the brackets and still not be able to launch the car like it should be launched.My .02.
The car launches just fine, 1.44 60' on a 10 bolt seems pretty good to me...unless I'm mistaken?
Thanks, I'm pretty proud of it. That was my VERY first time to launch the car w/out it breaking (Driveshaft turned into a twizzler before), the next 60' was a 1.47 and I knew I stalled it it a lil high, then I put it up after that run. With some more steat time I'm hoping for lower 1.4X's.
Not to be a dick, but can we keep this on topic...
I don't expect to get it narrowed for free..
letys say you do get it narrowed and the right axles and gears and everything you want done..and lets say money was no option..and everything went in your favor...you would still have the same crap *** 7.5" ring gear that is going to fall on its face..and the ONLY reason its held this long is cause the car is a Automatic. Period.
2. Moser or Strange can provide any axle you want. Even C clip axles but cutting 1.44 60's why would you want C clips. The wall at the dragstrip is very close when an axle breaks and walks out of the tube.
3. Measure you stock rearend and so how much room there is between the stock flange and the LCA mount.
And like everyone else has said if you build the 10 bolt strong enough with all good parts you will still break ring & pinions.
i can read what you said, i'm not an idiot. i was just giving you the best advice you could do and save $1500+ dollars on the 10 bolt and add maybe $800 to it and have a decent axle expecially if you ARE actually cutting 1.44's and not exploding the rear. it's only comon sense to me too invest money into something worthy of that much money, but maybe you don't care about saving money in the end and just like throwing money at pointless ideas.
1. Sure it is possible, just make sure someone has the correct tools to shorten and reweld the flanges.
Mods, before this thread gets too off topic, can it be locked and used for a reference incase anybody else is looking to do the same thing?
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
