Midwest 9 inch, vibrations help
Rear end set to -2, shaft at +2, vibrations come on around 90 mph
Adjusted the rear down to 0, vibrations come on around 110
Adjusted rear back up to about .5 vibrations came on around 100.
Adjusted rear to 1, and left it. I couldnt get the car up to speed at the time of day.
Now something to note. From 70mph to about 75-80 there is a very small vibration and at 80 MPH the vibration goes away ( this is under acceleration and decel ).
Now under accel from the last setup I could get up to about 100 mph with no vibrations. However on decel the vibrations came on at about 90mph or higher.
So to sum up some stuff and take the angles out of the equation. The drive shaft comes into the rear at a downward angle. With the pinon pointed in a upward orientation gave better ( less ) vibration results. When lowering the pinion to try and match the angle of the driveshaft coming in, the vibrations got worse ( more ).
Adjusted rear to 1, and left it. I couldn't get the car up to speed at the time of day.
So to sum up some stuff and take the angles out of the equation. The drive shaft comes into the rear at a downward angle. With the pinion pointed in a upward orientation gave better ( less ) vibration results. When lowering the pinion to try and match the angle of the drive shaft coming in, the vibrations got worse ( more ).
If the angles are even close, then there will be no issue as a result of the angles.
Your problem is the DS balance.
If you have the pinion at -2 and the DS a +2, this is wrong. That 4 degree angles on the u-joints. This will needlessly rob power and wear the u-joints out quicker. If you have it setup right, the u-joint angles will be about 2 degrees.
Vibes will occur if the two u-joint angles are different. For example if the rear u-joint angle is 2 degrees and the front one is =5> degrees, you got vibes. If the rear is 2 degrees and the front is 3 degrees, no vibes.
If the two angles are equal, it is impossible for the angles to be causing the problem which leads you right back to the DS balance.
For giggles I set mine up at 0 u-joint angle (testing only) meaning the crank/tranny, the DS and the pinion where dead straight as an arrow and i still had vibes. Again it was the DS.
IIRC. When my car is on the stands, my pinion reads 90 degrees relative to the ground and the balancer reads 90 +/- .5 or so degrees relative to the ground. The DS at the pinion points uphill 2 degrees. The DS at the tranny points downhill ~1.5 degrees. This gives me a -1.5 through -2 degrees pinion angle.
Little more info on the vibration issue. My local car club had a cruise and we played around. At one point on the cruise I did get the car up to the 120 mark... vibration from about 100-120 we pretty decent and I actually past the 120 mph mark. After 120 MPH the vibration went away... confused me some haha. Now the only logic I can apply to this is tires. Tires can have vibrations at certain speeds and the vibration can go away at higher speeds. So with this information I more so believe that the drive shaft very well could be the sole issue I am having.
I will report my findings later this week. I am dropping my car off at my local guy and letting him go at it. We found a local DS balancing shop that does lots of race applications. I believe we are also going to look at swapping around some drive shafts that he and others have to change the material of the drive shaft ( aluminum and such ).
It was the drive shaft. I ordered a new aluminum DS, vibrations are gone. Should of posted this a long time ago haha
My money is on the working angle of the front u joint being too great. As stated way early ITT by MWC, measure all the angles of your driveline, and go from there.
https://ls1tech.com/forums/manual-tr...vibration.html
