Which Rear End to get for a 6 speed car?
#41
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
#42
Well I didn't have it alligned perfectly and it was very rough locking/unlocking when I would shift. Once I got it straightened out better it was much smoother. The only thing that might bother people is when you're making slow tight turns like in a parking lot, it can get rough sometimes locking/unlocking. With a little practice though you can cut down on that a lot. It's a small sacrifice imo to know that you have the strength there when you need it.
We are discussing exactly what this thread is about, are we not? It's very important to choose the right diff. when you make your purchace. If you still feel we're hijacking though...... get over it.
#43
to the people who asked about my truetrac, on launches like the one in sig, it just tears the **** out of it.. it makes all kinds of noise around turns and stuff now.. if you are an a4 car i say go for it. its very nice on the street. hell even m6 on the street it was great. and at the track it wasnt my first time out that it broke but it wasnt even a year old and that not what i paid $2800 for.
#46
The reason I'm not going to get a 12 bolt with and M6 is because of how the torque arm mounts to it. With all the stress from shifting the bolts like to back out and I think the stock style bolts that the 9inch uses is stronger
#47
I bought a Midwest Chassis Fab 9 inch, I like the rear no doubt it was a nice rear end. If I could rewind time and redo things I would go with a Moser Fab 9inch or atleast another sponsor. The customer service was not up to par. You can leave message after message with no return. When youi finally get a phone call back, and talk to him you get little help and little assistance to fix the issue. Then you go back right to leqaving messages. Just poor on one end when you spend close to 4k. Just my 2 cents.
#50
And to answer your question, yes. A lot of M6 cars have broken 12 bolts.
#51
are we talking about a locker or spool there.
ya that makes two of us
#52
NNSANE im a newb so im jus hearing it off Tech. What components would you suggest in a MWC fab 9'? car will be dd, m6, want light as posssible and bulletproff b/c i wanna be able to dump the clutch at 5k+ all day everyday but i mostly just street race rarely see track. end result H/C/I + 75 shot hoping to be around 550hp what componets the best you can sum it up for me? thx and feel free to pm
btw I was talking about a locker in that other post.
#54
LS1Tech Sponsor
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#55
LS1Tech Sponsor
If you're looking for something bullet proof and light weight a spool is what you want. The downside to that is accellerated tire wear and slight popping on tight turns. Or you could go with a locker which is also very strong and it's easier on the tires because it unlocks the diff when you turn, but again you will have slight popping when it locks/unlocks. Either way, you'll have to sacrifice something to get what you're looking for. My advice would be to find someone near you that has a spool or locker and take a ride with them to see if it's something you can deal with or not.
__________________
#56
I've had several customers have problems with lockers and their six speed manual transmissions. If you rotate a driveshaft back and forth that is ahead of a locker, it will appear that there is way to much gear backlash. This is because of the locker and is normal. This extra play can cause a manual transmission to have problems shifting at part throttle driving. Wide open throttle shifts are not a problem. This problem doesn't appear to everyone who has a locker and a manual, but out of all the lockers I have sold, it has presented itself several times. Bob
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
#57
LS1Tech Premium Sponsor
Neither Moser, Strange, nor myself manufacture gearsets, we just assemble center sections with a good quality gearset from another manufacturer such as Motive, Richmond, US Gear, etc.
while excessive gear noise is possible from incorrect setup, chances are that there is nothing wrong with the setup and the gear itself is simply designed for strength and lower cost of manufacturing so you end up with a gear that will make some noise. add all this up with a car that has a tuning fork(torque arm) bolted to it and in most cases much more solid mounted than stock, and the noise that the gear does make is transmitted into the passenger cabin much worse than any other car out there.
we have recently started to use a different manufacturer for gears that has focused on making a gearset for the 9 inch that is lighter and quieter than the average Richmond or Motive gear without sacrificing any strength. there is a limited quantity of these available and I just made a huge purchase of them to be sure to have the more common ratios available as the supplier has basically sold out of them for the next several months. we have already used several of these gears in the more recent builds with great results so far.
#58
back to subject now...
we do not recommend the locker due to its driveability issues, especially with a M6 car. a Locker is a good diff, but was not really designed for this application. some people like them, some hate them. I suggest to find someone that has one and ask for a ride or drive before you make the decision.
if you are in the need of 35 spline axles, the Wavetrac diff is really the way to go. it is costly up front, but with its lifetime warranty and design, it is the best thing on the market right now for a smooth diff unit that is durable. there is another 35 spline diff in the works right now that will be durable and a bit less costly, but is currently not on the market yet.
in most cases a good trac-lock posi with aggressive preloading will be plenty durable for most street/strip cars. we use a billet case unit with carbon clutches in opur builds and have had very good luck with them, but it is limited to 31 spline. 31 spline axles are usually good to the 1.3 60 foots and 9 sec. quarter miles. the trac-lock posi is also rebuildable!
in choosing rearends it kinda goes like this... auto trans car(without transbrake) a 12 bolt will be ok with any diff unit.
M6 or t-brake auto car that sees hard launches or any type of track use we generally point you in the direction of a 9 inch or S60. there are several diff units for the 9 inch and the Truetrac in the S60(35 spine) is plenty durable.
#60
He has now taken the needed changes to better help his customers, if there is something you need help with please PM me and let me know what I can do to help you out with your situation.
