how to remove gears?
I am looking at a ten bolt out of a ws6 in my garage with 3.42 gears, I am trying to pull the ring and pinion out of it. I have removed the bearing caps, the small 5/16 bolt that runs thru the posi, and the steel block in the middle, also have removed both c clips, and pulled the axles out. Should the ring/posi unit pop out now? is it just stuck in there? should I pull hard on it?
I had a hard time getting my gears out as well - I found a prybar did the trick. On the driver side you can rest a prybar against the axle and pry on some of the bolts on the carrier.
and DONT use a hammer on the pinion threads to get it out,, there is a nice dimple in the end of the pinion, an air hammer with a round blunt end will push the pinion right out without damage to the threads
with my lack of knowledge and word terminology, I somehow Managed a ring & pinion swap, and swapped whole rear ends in my car. Now I am cruising with 4.10's instead of 3.42's in my m6 z28.
I am loving it.
third day now, and no signs of anything odd.. quite as stock.. I ran it hard the first night to make sure nothing was going to break, because if it was, I wanted it to now.
Now whats the cheapest way to fix my speedometer lol?
I am loving it.
