Building a junkyard 9" compared to 8.8
#222
Man you mean to tell me that noise bothers you so bad you are thinking of buying another gear. Your gonna have $600 in gears in that thing.
How about buying a set of long tubes and a nice loud exaust. Should quiet that gear right up.
Lol.
Lol.
#223
There is another 6 cyl manual truck over there that has one in it to, I may go get it later next week just to have it, only $30.
#225
Well here she is, this thing was really nasty on the outside. I guess it is 40 years old though. After about 45 minutes in the parts washer, I sprayed it down with some brake cleaner then blew it dry to get ready to put on the marking compound. The patern looked really good and consistant all the way around the gear. Also the back lash was good at .010 with no runout on the ring gear. It made me feel good seeing USA and FORD stamped on the pinion. It really is a shame because I dont think I have ever seen a ring and pinion with USA stamped on it. To think that stuff made in the USA just keeps going away...
All I have to do is match this pattern and I should be good.
I loaded the gear as hard as I could in this picture and you can see a circular pattern in this picture if you look hard enough.
Clean and ready to go in the car.
#226
We as americans have become consumers rather than the manufacturers we once were. The country that discovered the steel making process cant produce a steel product cheaper than it can be boated over by some charlie raking in our money without paying a nickles import tax.
#227
#233
I'm sure you can do it if you're inclined to do so. I sort of did the same thing in my '80 Malibu 20 years ago. You might end up close to what I sell the Moser housing and axle package for, here is a link to it. http://shop.brutespeed.com/Moser-9-I...-and-Axles.htm You could use the Moser and use a junkyard center section. Just an idea, as the little parts cost and time can add up. Bob
IT pisses me off everything i think about all the work and money i spent to make this when i couldve bought better cheaper, and without labor.
#235
LS1Tech Sponsor
i didnt read this whole tread but i want to say i just built a junkyard 9 inch for me. I did it right, replaced the tubes with new 3.25 steel tubing,used moser housing end caps, moser axles and spool, rebuilt the center section with a nodular case,welded brackets on. Well anyways the main point is i spent WAY MORE for a WAY CRAPPIER rear end that i spent TO MUCH TIME on when i couldve just got a moser complete rear.
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#236
Well run the car on jack stands last night, good news and bad news. I still have gear noise. But, I dont think its coming from the rear end. I think its the T56. I can run it from 20 to 80 mph in 4th with no noise. As soon as I shift into 5th and do the same thing I start to get noise, then put it in 6th and it gets louder. Same mph in 4th no noise, same mph in 5th start to hear noise, same mph in 6th noise gets louder. The drive shaft is spinning the same speed at that mph no matter what gear I am in, just turning more engine RPM. So, looks like I might be learning how to rebuild a T56 transmission.
Going to drive it as soon as the monsoon lets up here....
#237
Theres a series of needle bearing that go between the input shaft and main/output shaft that allow them to turn at differn't speeds. The counter shaft runs along the side and uses a series of fixed gears to mesh them together. But in 4th gear only your locking ring instead of making a gear selection locks the input and main/output shaft together for a 1/1 ration and that bearing is then not functional at that time. Wish you woulda came up with that $600 dollars or so. LOL.
#238
What do you mean? I drove it last night and still have noise, its is better so it is still making me think it is the rear end... Now I have noise on coast, the drive noise starts at about 55-60 under light throttle. The wierd thing now is it goes away on the drive side when I am hard on it. Under hard aceleration no noise.
#239
#240
I meant if it were the trans I wish for your sake that you woulda realized it before you changed gears twice. If I were yo I would just try to stay on the throttle all the time. LOL. When you are taking this thing apart do all your bearings look good and well lubricated?
That’s what I thought you meant...Somehow I knew I was going to get the response to stay on the throttle all the time....I just knew that was coming...LOL I wish. The bearings look fine; feel fine every time I take it out. I am going to move the pinion out .001 one time tonight with everything still in the car and see what that does. Just like I did with the Yukon which did nothing...hell I might even go .002 this time.
