Need input on building a 9"
Old Dec 13, 2010 | 09:42 PM
ls1allday02's Avatar
Default Need input on building a 9"
Got a 9" out a 77 f100 going in a 02 camaro. I measured axle flange to axle flange on both 9" and stock rearend. 9" is 1" longer than stock i think i can deal with that any doubt please correct me. Anyone did this before input can be useful!! Thanks
Old Dec 14, 2010 | 08:39 PM
96lt4c4's Avatar
I am thinking about doing this myself. What kind of rims and tires are you going to be running? Bolt pattern is going to be wrong. You would have to have axels made so why not make the housing the same width as stock. That would be my plan.
Old Dec 14, 2010 | 10:14 PM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
If you are looking at making it fit to your vehicle we can get you into the proper housing ends and all our laser cut brackets. They will need to be welded onto the housing of course. We can also get you set up with axles. If you want to go the next step we also offer our bolt in torque arm and cross member with the weld on tabs for the housing. This takes some fabrication and welding skills but this is something we have sold many that are building their own rear end.
Old Dec 15, 2010 | 10:21 AM
96Lt4C4
Because i dont think it would be worth cuttin an half inch off of each side to make it to stock width. My wheels are 17x10 with 275 40 mt street and they tucked in a good bit so i think it would be ok.
Old Dec 15, 2010 | 10:25 AM
Midwestchassis
YES maybe i can use some of your products pm me prices if u dont mind.....Thanks
Old Dec 15, 2010 | 11:08 AM
I get back to the shop I will PM you the prices on everything.
Old Dec 15, 2010 | 11:10 AM
K Thanks
Old Dec 17, 2010 | 04:59 PM
96lt4c4's Avatar
If you dont mind what are the widths of both rearends. Stock and the 9".
Old Dec 17, 2010 | 05:14 PM
Valkyn's Avatar
If the housing is 1 inch longer on each side then you are either going to have to shorten it or run rims with 8.5 inches of backspacing...im not sure if anyone makes rims with that much backspacing.
Old Dec 17, 2010 | 05:55 PM
89 formula350's Avatar
i think he ment 1" total so .5 each side is not much
Old Dec 17, 2010 | 06:18 PM
Valkyn's Avatar
So you will be okay if you can find rims with 8" of backspacing
Old Dec 18, 2010 | 01:22 PM
The stocky is 64 1/2" and the 9" i have is 65 3/8" and this is not housing meas. This is axle flange to axle flange measurements. So it is 7/8" longer than the stock to be exact.
Old Dec 18, 2010 | 02:47 PM
Anyone running excel richmond how are they holding up strong enough for 5k + launches?? Iam going to go with 4.33 or 4.56 not shore yet...
Old Dec 18, 2010 | 04:38 PM
96lt4c4's Avatar
Is that a posi, spool? Do you plan on running stock brakes?
Old Dec 18, 2010 | 05:22 PM
Spool.....I want to use the stock brakes i will be lookin over my options to make it work this week...tomorrow i will be welding the brackets on. I will be trying out the mini ladder bars as the fela did on the 8.8.
