Midwest Chassis Fab 9" rear end/ Direct bolt in
I ordered my Fab 9" rear end Base package with Black Powder coat,Meziere rear side filler cap, & Strange 31 spilne axles machined for the stock ABS/TCS traction control Reluctor rings.
This rear end was a direct bolt in. Rear came with Timkin bearings, seals & all hardware for install. No modification necessary.
Eric advised me to go with 2" shortened axle on each side to fit Weld 15x10" 5.5 backspace wheels for running Deep Dish Weld wheels.
Eric also advised me to go with his short torque arm. He said this would be best for my automatic equipped car. He said the short arm shocks the tires more.
The transmission cross member, Torque arm mount, & Driveshaft Loop are fabricated in one unit. This relocates the Torque arm off of the transmission & places the load on the newly supplied cross member to take the load off the transmission. Torque arm is made of Chrome moly steel.
This is the most complete Fab 9 rear end available.
Eric & Jason both advised me & helped me make the correct decisions for my application. Best customer service that i have ever experienced.
Thank you Eric & Jason...!!
