4000 stall/gears?
Old Jan 28, 2011 | 12:56 AM
Teakwo23's Avatar
Default 4000 stall/gears?
Hey guys, i just had a 4000 yank installed on my car. Its had a tune after wards. The car is a bit loose for street driving. I drive it mainly to work and around town. It sees a little highway use. Would a gear swap make any difference, as in tightening up the converter. If so how much? Its got the stock 3.23 SS gears option. Thanks.
Old Jan 28, 2011 | 01:41 AM
SS SLP2's Avatar
yep, will tighten up the converter , as to how much? the more gear the better. 3.73 may be best in the 10 bolt, 3.90 be better but the higher you go the smaller the teeth on the gear set
Johnny
Old Jan 28, 2011 | 01:50 AM
01ssreda4's Avatar
When I switched to 3.73s my part throttle tightened up about 500 rpms.
Old Jan 28, 2011 | 11:50 AM
Teakwo23's Avatar
Thanks for the info guys. Is there a certain set of gears that are quieter then others?
Old Jan 28, 2011 | 08:21 PM
SS SLP2's Avatar
I like AAM gear
Johnny
Old Jan 28, 2011 | 11:51 PM
Teakwo23's Avatar
Default difference?
DId you notice a difference with the 3.73?
Old Jan 28, 2011 | 11:52 PM
Teakwo23's Avatar
Default aam
Originally Posted by SS SLP2
I like AAM gear
Johnny
Where can i find AAM?
Old Jan 29, 2011 | 11:14 PM
SS SLP2's Avatar
search for "texas drivetrain performance"
also try "jaws gear and axle"
you may like US GEAR and YOKON GEAR , I like AAM best of the three
Johnny
Old Jan 30, 2011 | 12:43 AM
Teakwo23's Avatar
Thanks
