Yukon gears for 9"
Yukon gears for 9"
anyone have them,i think they are pretty new.They are suposed to be nice and quite,so would like to hear from people who have them.I have richmonds now and they are just way too loud
LS1Tech Premium Sponsor
I retract my last statement....Yukons suck. Buy Motive performance gear, Orange box. Gears have gotten really crappy in the last few years, the Motives are still decent, for the 9 anyway. I was told this straight from Moser.
And my Yukon are making noise....
I have found an original Ford 3.70 to put in mine.
The first time I put the center in I drove the car 5 miles tops with them making noise so, I pulled the center to check the pattern. I did not want to hurt the gears. I never really was able to get a pattern on them that I liked so I should have just sent them back, before I drove on them. They are setup in a Yukon Aluminum threw bolt case as well. So, I thought maybe there was a machining error in the case so I set them up in the factory Ford case and the pattern was the same. After I reinstalled the center and they still made noise I just decided to drive the car. I have driven the car to work and back so they probably have about 70 miles on them now. This is the best pattern I could get out of them. Please feel free to tell me if you see anything wrong because I am about ready to give up. The pictures are with a .025 pinion shim and .010 back lash. The coast would not come off the toe even at .015 back lash. I have always liked Yukons stuff but this has been a bad experience. Also everything else is new, Yukon install kit.
After talking to Moser on the phone yesterday it all made sense.......
That sucks. Before I purchased the tools to setup gears correctly I used to just set them up by feel and center the wear pattern nicely. Even used gears I would do this way and I never had a single problem. But cars were always hot rods and had loud exhaust on them also. Nothing crazy but loud.
Sorry your having such bad luck.
Have you contacted Yukon to ask them about possible warranty?
Here is a good read from their web site.
http://www.yukongear.com/Downloads/T...structions.pdf
Moser said that all the gears being made right now are junk and they have to deal with this all the time, and that if I was going to install an aftermarket gear that I should use Motive performance gear, Orange box. They told me Yukon gears are made in India and that US gear is out of buisness and that if you buy a US gear right now it will be made in China.
Here is what is going in it now, OE Ford 3.70 from a 1969 F100, 300 6 cyl, and 3 on the tree. Pulled it from the truck this morning....
Straight from Yukon rep....
My rep said, your pattern looks good.
Those gears have a potential to make slight noise.
The 3.70’s would be quiter ( none in stock anyway ), he said.
“ nature of the beast” those 375’s.
well i found a set of yukons from Randys ring and pinion.I will give them a try.The guys at midwest who deal with 9" stuff so much say they are pretty quite.So i will give them a shot.
