9in guys , i need help
i have a q/p 9in in my car now and i need a shaft . i hear from places the stock shaft is the correct length but i need a conversion u-joint . i have a 1350 yoke on my 9 in is there any truth to this orrrr not so much ????
thanks for any help
thanks for any help
I'd actually around an inch longer drive shaft. It's recommended.
http://shop.brutespeed.com/PST-3-1-2...Driveshaft.htm
Check this out This is what I have with my 9"
what is the part number on the conv u -joint ? im gonna mock it up and see where it is . if its close im gonna use it and see what happens . if it makes it this season ill buy one next yr . or if it breaks , ill get one then lol
Idk about part numbers but you should be able to get one at any speed shop. I have a competition engineering one for example. I believe you just need a 1310-1350 conversion u-joint.
Conversion U-Joint - Stock 3R to 1350
SKU # E-U3R1350
Price: $43.50
From Spohn
I had to get a new drive shaft made up after my 9" install. If I remember right is was 46" long. I don't know what factory length is.
SKU # E-U3R1350
Price: $43.50
From Spohn
LS1Tech Premium Sponsor
The correct Precision number is 447 and the one we use. Now keep in mind your drive shaft does end up short when doing this swap. However for a DD style vehicle we have not had to many issues. For drag race application we do not recommend doing this though because of the simple fact you are pulling the yoke out of the transmission housing by that much and it is not getting proper engagement.
The cost of buying the proper drive shaft once can save you hundreds in damages later.
