9 inch pinion angle help
Then you measure from the torque arm mount where the 2 bolts go through. Then measure your drive shaft angle. Add the two and that is your pinion angle.
From there just adjust the torque arm until the total of the TA and the driveshaft equals between -1 and -3.
The problem with the generic number thrown around that you adjust it to 2 degrees down is that while it may be right for a car at stock ride height and suspension, on level ground, all the relative measurements change with a 9", tire heights, and even a little bit from changing motor mount setups. With the method of adjusting as I described, (assuming you could still load the suspension to ride height) you could mount your car horizontal or upside down (again, hypothetical) and still get the correct pinion angle set. Its all about the relationship to the crank centerline and how much the yoke moves upward under load.
