Moser 9 Popping?
Ive had this in there for about 4 months, bought it used. For some reason when backing out of like my driveway or parking spot theres a popping noise coming from the rear. Only 2-3 pops and it stops. Same thing going forward, it pops a couple times when leaving a stop sign/light.
Its got 3.50 gears, 33 spline axles, posi.
Also, I replaced the passenger bearing and seal about 3 months ago, replaced pinion seal/all bearings in pinion support, fluid checked weekly and use gm posi additive.
Whats up with that? Just started about a week ago...
Its not the Detroit I know that. Im not sure which one but im pretty sure its a Trac Lock. It may be the diff, kinda what I was leaning towards but I thought somebody else might have had the same problem.
Not the LCA bolts, everything back there is fresh and was properly torqued and checked multiple times after I put it on.
LS1Tech Sponsor
Only if the rear is hitting the sheetmetal. Look for the torque arm bracket to be rubbing the floor, it normally can make contact in two locations when a car is lowered. All you have to do is to take a prybar and pry the floors sheetemtal away in these areas. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
Its not hitting anywhere on the body. It did before I adjusted the panhard bar, put a hole in it behind the back seat by the tunnel but I fixed that. I just put a new catback on too and put vibration dampner on all the back of all of the heatshields and checked again then. It sounds like its some slack in the gears or something but I havnt changed anything so idk why its doing it all of a sudden...
LS1Tech Sponsor
If it has a Truetrac you could be in for a new differential, as they start making popping sounds before the fail. Bob
![](https://www.brutespeed.com/Pictures/trac_loc.jpg)
Trac Loc
![](https://www.brutespeed.com/Pictures/truetrac.jpg)
Truetrac
Trac Loc
Truetrac
__________________
Well theres no way to tell without pulling it out right..
I pulled out the pinion support to put a new seal in and bearings and from what it looked like it appeared to be a Trac Loc but not 100% sure.
Whats so bad about the Tru Tracs in these cars? I put one in my truck and beat it all the time and it never had a problem or even made a noise
I dont see why theyre so bad like I said earlier the one in my truck was abused daily and never gave me a problem... But hey i guess only time will tell. Just dont see why it started it all of a sudden...
