whats the most i can narrow my rearend with frame rails in stock location
whats the most i can narrow my rearend with frame rails in stock location and what size offset wheels would I have to run let's say 15x10 or 15x12.
Im a little more than 3 inches narrowed more like 3.75 running a 15x10 3.5 bs. bump stops removed,home built mini tubs/BFH the fender wells . Tucks a 275/60/15.
what would the amount of narrowing if i used a 1.5" bs wheel? i figure if you get a set of prostars or something similar on a stock rearend theyre 7.5" bs so with a 1.5"bs you could narrow like 5-6" each side?
weight reduction and i thought about it and it probably wouldnt anyway because i forgot theres only so much room between the end of the axles and the frame rails.
