Anybody ever drilled out a backing plate?
As a last resort before taking an axle in to a machine shop to get some wheel studs swapped out, I'm thinking of drilling an access hole in the backing plate. Looks like some tough ****, and I was wondering if anybody ever tried that successfully before?
Yeah, taking the old studs out isn't the issue, but getting new ones in is. As mentioned, there is a hole that the ABS/TCS equipped cars backing plates have drilled out already, and you can get a ratchet in there to remove the studs. The only issue is trying to drill the backing plate out while attached to the axle. I've got new bearings and stuff on the way if I cant get it done myself and have to go to a shop, but I'd prefer not to do all that.
I drilled mine to fit on a 2nd gen (stagged shocks means staggered brakes - fun). The backing plates are iron. A drill press with a good bit should cut through them in no time at all.
Are your studs press in or screw in? My originals are press in (hammer out). My Wilwoods (front) are screw in, and Moser (back) are press-in.
