is it okay to use used axle shaft? thoughts on axle repair bearings?
Just had my diff replaced with an auburn diff on my '00 z28. My mechanic said that both of my axle shafts had wear/damage on them, and therefore would need that addressed relatively soon (f*** me, right? I'm a student with very little money). he said I'll need new axle shafts, bearings, and seals. My question is, can I get used axle shafts, if there is no damage on them? My mechanic said I HAVE to get new ones...but idk. Also, I do know about those axle repair bearings, and that they actually work, even though they are tricky to install. Should I do that, since my budget is very limited?
and considering the fact it's also pretty stupid to be rebuilding a 10 bolt, should I just opt for the axle repair bearings? I have never taken this car to the drag strip, nor do I plan to. It's my fun daily driver, and I drive it pretty lightly in hopes of maintaining it well, with occasional pulls and slides and stuff, but rarely do I launch it hard.
Getting used axle shafts is just fine as long as the bearing surface is in good shape. That's what I did on my old car that had a chewed up bearing surface. Never had a problem with it.
Those "axle repair" bearings are crap. Highly likely to leak since the seal is thinner to relocate the bearing, and then I've seen a lot of reports that you cannot get the C clip out with those repair bearings as they don't allow enough inboard movement to release it.
I think I can drive it, but the second I hear a change in the sound, I'll be taking it to my shop. Yes, no?
You could stick new bearings in and put the current axles in there, but no saying how long that would last. Sometimes they'll tear up the near bearings really quickly, other times they'll be OK. All depends on how bad and what kind of wear the shafts have. Have you seen them? They pitted/grooved or just discolored but still smooth?
Plenty of good used rear ends for $200-300 just punch your zip code in the parts locator on www.car-part.com. Don't leave out the dash that's a different site...
Then you can sell off or part out your current rear , someone may want the housing , people use the tubes to weld on a 8.8 or similar swap , maybe keep your auburn for a spare since you know it's recent or sell it to help fund the new used rear.
The way your mechanic has you heading parts and labor will be double the cost of a junkyard rear.
