12 bolt or 9" ????
Old Dec 4, 2001 | 09:46 PM
BIGBOS's Avatar
Default 12 bolt or 9" ????
Which would be better for my use...I've heard of 12 bolts breaking??
I am interested in a new rear sooner or later... <img src="images/icons/smile.gif" border="0">
Old Dec 4, 2001 | 10:57 PM
minty's Avatar
Default Re: 12 bolt or 9" ????
PROGRAMMING....thats FIRST.... <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Old Dec 4, 2001 | 11:05 PM
ExtremeZ28's Avatar
12 bolt! Colonel and Nineball have em and there running pretty freaking fast so what the hell?? why not copy the fast guys <img src="images/icons/wink.gif" border="0">
Old Dec 5, 2001 | 01:10 AM
ChrisB's Avatar
If I were doing it again, I would go with a 12bolt, albeit with axles a little larger than the 33spline. (I have a 9" now).
Chris
Old Dec 5, 2001 | 06:39 AM
2000 Camaro SS's Avatar
[quote]Originally posted by ChrisB:
<strong>If I were doing it again, I would go with a 12bolt, albeit with axles a little larger than the 33spline. (I have a 9" now).
Chris</strong><hr></blockquote>
Chris did you twist the 33 spline? Would you have bought the 35 spine if to do again?
[ December 05, 2001: Message edited by: 2000 Camaro SS ]</p>
Old Dec 5, 2001 | 07:39 AM
BIGBOS's Avatar
Yea I will most likely go with a 12-bolt after looking into what those guys have done.. <img src="images/icons/smile.gif" border="0">
Old Dec 5, 2001 | 08:41 AM
Colonel's Avatar
Moser 12-bolt with a HD Eaton work fine for me.
Old Dec 5, 2001 | 11:45 AM
DJ's Z's Avatar
Diddo...12 w/ HD eaton...I've had no problems, car at 3700lbs, leaving at 4000-4500 on E/T streets...1.53 60'...better 60's on the way !! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Dec 5, 2001 | 01:34 PM
Camaroholic's Avatar
What are your center section options when looking at 12-bolt 35-spline axles?
I plan on launching at high RPMs on slicks, yet I will be driving the car on the street quite a bit (since the track isn't open all that much).
I'm thinking soft locker, as I don't think anyone offers a posi in 35-spline configuration.
-Andrew
Old Dec 5, 2001 | 09:20 PM
BADZ's Avatar
Moderator
Strange 12 bolt w/33 Spline axles, Stange has an upgraded set of axles that has the 4140 Heat treaded A-36 mild steel...Works great and not to worry about twisting.... <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
[ December 05, 2001: Message edited by: BADZ ]</p>
Old Dec 5, 2001 | 09:46 PM
AAron's Avatar
9" with 31 splines here 4.10
Old Dec 6, 2001 | 12:42 AM
ChrisB's Avatar
Nope, haven't had a problem with my 9" axles yet - but 2 friends with a 12 bolt have both killed their 33 spline axles. I just blew up my centersection (actually just cracked it).
Chris
Old Dec 6, 2001 | 11:27 PM
Quickin's Avatar
[QUOTE]Originally posted by Colonel:
[QB]Moser 12-bolt with a HD Eaton work fine for me.
__________________________________________________
WOW! I don't know when you did it, I just noticed your sig, "9's"
Congrats man!
Quickin
Old Dec 7, 2001 | 12:06 AM
Colonel's Avatar
Thanks! <img src="images/icons/smile.gif" border="0">
I posted a link to it at LS1.com but the title of the thread didn't specifially state NA 9s so you may have missed it because of that.
Stay tuned for 8s. <img src="images/icons/wink.gif" border="0">
Old Dec 7, 2001 | 12:35 AM
Quickin's Avatar
If you don't mind me asking, do you keep reducing wieght or do you also mod your engine for more power too?
Old Dec 7, 2001 | 10:52 AM
KTamez's Avatar
FYI The highest spline count on a 12 Bolt that can be had w/o going to a spool is 33. Even the 33 Spline is only the Eaton posi, that is resplined after leaving the factory.
Stephn, Ya know you could drop a couple more #s with a Spool, and then put even more hp to the ground... <img src="images/icons/wink.gif" border="0">
Kurtis "Wantin a Profiled Aluminum Spool" Tamez
