Which posi in 12-bolt?
Old Nov 24, 2005 | 03:19 AM
MattZ28's Avatar
Default Which posi in 12-bolt?
Stripped 2 teeth off the ring gear in my 10 bolt tonight at the track, so I'm ordering a 12-bolt soon. Which posi should I get? If I drop $2500 on a rear and have the posi unit go out, I will kill people.
Old Nov 24, 2005 | 03:53 AM
MattZ28's Avatar
Also, is the $100 33-spline Eaton option for the moser the Heavy Duty unit? Is this a good posi? I'm looking at this and the Detroit TrueTrac.
and is the aluminum support cover worth it? I'm tight on cash, so if it's not mandatory, I'd rather not get it.
Old Nov 24, 2005 | 09:43 PM
MattZ28's Avatar
Now...how the hell did only half of the teeth break off??
Old Nov 26, 2005 | 01:48 AM
MattZ28's Avatar
Please guys, I need to order this ASAP...
Old Nov 26, 2005 | 04:43 AM
Jimmy P's Avatar
I would say ifyou realy dont want to have to replace the posi, get the TruTrac. From what I have read its a prety stout piece. I got the $100 option for the "heady duty" option with my Moser 12 bolt, and about 3,000 miles later I'm doing one wheel burnounts. I will be either getting the Trutrack for a locker.
Old Nov 26, 2005 | 07:54 AM
steveo346's Avatar
well that sucks jimmy....hey matt go with that eaton posi unit u cant go wrong with them...carbon fiber clutches oh yeah!!!!
go with the aluminum support cover from thunder racing it looks awesome and give better support that that crappy stamped steel one that comes on the car
Old Nov 26, 2005 | 08:40 AM
MattZ28's Avatar
thanks anyone else?
it seems like alot of people have problems with the HD Eatons...I haven't read anything bad about the Detroit though.
Old Nov 28, 2005 | 05:56 AM
01SLPSS's Avatar
Go with the Tru-Trac, I have the HD Eaton and hate it, Going to be pulling 12-bolt rearend to put Tru-Trac in soons I get the money!!
Old Dec 4, 2005 | 07:09 PM
1badA3Z's Avatar
if ur going to spend that kind of money get the best of the options they offer u
Old Dec 5, 2005 | 04:38 PM
as35thss's Avatar
Just ordered my 12 bolt with the true track. Should be shipped out tomorrow. Maybe be here friday. I will let you know how it is. I am going to go threw it and make sure the set up is right.
Old Dec 5, 2005 | 06:37 PM
pushinfreight's Avatar
I have done a bunch of research on this lately and this is what I have found. The true trac seems to be about the best thing out there if you are looking for a posi unit. If you go with the true track then you will be getting a mosure setup. The heavy duty eaton is the best after that. Now if you are just looking to go in a straight line and do not care about cornering then get a locker and be done with it. From the looks of the car the locker will be the better choice and is cheaper.
