How to Replace Axle Bearings in 99TA?!?
If you needed to replace any bearings inside the rear end, you'd be hearing a good whine/howl going down the road, and may even find metal shavings attached to the magnet.
I tried to repair one of my rear axle bearings, but I couldnt get that fu*ker out! I tried everything, including bearing puller, prying on it, propane torch, huge slide hammer(which almost pulled the car off the jack stands), and yelling at it. I took it to Midas and they said they had to use a hydraulic ram type of thing to get them out.
I'm rebuilding my 10 bolt on sawhorses, so it's easier to get at, but nonetheless... I heard about taking 3/4" water pipe, ~6' or so, and sliding it through from one side, to the other, catching it on the back of the bearing, and hitting the pipe until the bearing pops out.... I got one out this way (copper pipe too, not even steel!), but the other one I ended up knocking EVERY SINGLE roller out, and couldn't get it out. Rented a 3 jaw slide hammer puller, took 5 mins and got it out. Seals came out with the bearing.
putting in new bearings: just slip your new bearing in as far as it'll go, .5" maybe, then put your old bearing outside of it, put something flat across it (I used a piece of 2x8 wood), then just smacked the wood until the old bearing drove the new one in. Seal: put it in place, use your 2x8 and hammer the wood. Once it's flush you're done. Then I would put some axle oil on the bearings, and spin it with your finger to make sure it's well coated. mine were pre-greased, but clean on the inside, so I oiled them....
no special tools needed, pretty easy overall... Mine is a case from hell though, the cross shaft was a PITA to remove as well...
