moser 12 bolt filter???
Old Jan 20, 2006 | 02:37 PM
eas020223's Avatar
Default moser 12 bolt filter???
there anyone who has ever made or bought a filter for the breather hose?Trying to limit the amount of gear oil that leaks out of the breather hose becouse i have the sts turbo and my air filter is back there thanks
Old Jan 20, 2006 | 02:57 PM
CTSmechanic's Avatar
First off if its venting its over filled once thats taken care of UNI filter makes a nice filter PN UP-101
Old Jan 20, 2006 | 07:42 PM
DeltaT's Avatar
CTSmechanic, I filled the normal way - to the bottom of the fill hole. I still get oil coming out the filter if I have it installed. How do you fill yours?
Thanks,
Jim
Old Jan 21, 2006 | 06:27 PM
eas020223's Avatar
moser told me to fill to the plug on the side of the housing not the fill plug on the housing cover. if thats the case mine is over filled
Old Jan 21, 2006 | 08:26 PM
I had a 9 inch and was going to use the same method we use in our rearend housings on the race trucks... Inner axle seals with a -8 vent line a small baffel welded inside the housing...... I like to run the oil level where I can barely touch it with my finger
Old Jan 21, 2006 | 11:51 PM
DeltaT's Avatar
Where's the plug on the side of the housing?
What hole are you using?
Thanks,
Jim
Old Jan 22, 2006 | 12:40 AM
eas020223's Avatar
i used the one on the rearend cover. but from the rear of the car on the right hand sikde there is a plug on the axle housing behind the rear end cover and moser said thats the full plug marker??
Old Jan 25, 2006 | 04:16 AM
DeltaT's Avatar
Thanks, I'll check.
Jim
Old Jan 26, 2006 | 01:48 PM
onebad82z's Avatar
I don't use the holes on my moser's TA cover at all.I have them sealed up with silicone as they had a nasty tendency to weep oil.
On the passenger side of the rear center pumpkin there is a fill plug that requires a 9/16" allen head to remove or tighten.With the car level fill the rear with oil till it just starts to come back out of that hole.Install fill plug and tighten.Done.
