is it true that the stock rearend in a LS1 is weak?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
ive been thinking about putting 4.10 gears in my rearend. although ive heard that it would be better to just replace the whole thing since they are weak. if this is true im concerned about putting many bolt'ons and snapping my rearend any advice?
I can tell you from personal experiance that if you plan on modding your car and dragging it or even put drag radials out back save yourself the hassle and go buy a 12 bolt. I blew 3 rears before I got smart enough to buy the 12 bolt. With the time and money you would spend buying or rebuilding stock rears you could have got the 12. JMO though.
yea buying a new rear hurts but it is definately a must. i just ordered a 9 inch from Exotic Performance Plus, and though it was a chunk of money, i relieved to not have to worry about my rear crapping out.
well the 10 bolts a weird thing. theres guys on here who have made passes slicks and 4 10's and they still hold up. others make passes on d/r's and stock gears and they break.
10 bolt has a mind of its own.
i had a stock rear end on my car.. and i went 10.70 spraying 150 out of the hole with no problem and i did it twice.. and also like 4 times with a 100 shot of spray but still ran 11.30's.. and i had a eaton posi, richmond 3.73's.. and a TA cover ofcourse..no other modification were done to the stock rear.. and right now a friend of mine.. has a stroker on the stock differential running 10.10's and he's pushing way over 400ftlbs of torque on motor alone.. dont believe me click here or copy and paste.. its the white ss lt1... http://str1.com/v/triplethreat.wmv
Whats a crush sleeve eliminator? Same as shimming the spider gears 5 thou?
Whats the "tubes" and why weld them? Are you fusing them together or cutting them altogether?
Whats a TA cover? Trans-axle? Same as Harrop diff hat?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
A crush sleeve eliminator is also known as a solid pinion spacer. Instead of using the generic crush sleeve, which is a round piece of metal that collapses under load to get the correct preload on the pinion bearings, a solid spacer and shims are used to get the correct preload. The crush sleeve has a tendancy to loosen over time and allow the pinion gear to "walk up" the ring gear, which decreases the life of the gears.
The axle tubes are the long tubes that extend out of the center section of the rear end. The point at wich the axle tubes intersect with the cetner section can be fully welded (rather than the puddle weld that holds it in place stock) all the way around the tubes to add a little strength.
"TA" manufacturers a 1/2" thick aluminum differential cover that replaces the stock cover. It is supposed to add strength to the case and help prevent case distortion.
ok so lets say i jus wanted to keep my LS1 for strictly street racing...if I put some basic boltons (intake, headers, LS6 heads,exhaust...would i need to change the rearend or would it be ok?
As stated above the 10 bolts do have a mind of their own. But to help prevent damage you should start by maintaining your rearend. When was the last time you changed the fluid? I drove on my 10 bolt for 1 year stock, 2 years bolton mods & dragradials, 1 year cam, nitrous & dragradials. Until I snapped my drivers side axle. In the end I put over 50,000 miles on it before I had a problem. Luck maybe but I maintained it changing the fluid often. So if you just use some boltons and maintain it you will problaby be fine.
Originally Posted by blue01ta
If the gears themselves aren't weak, why does one set blow the rears apart more than any other?
