Trying to decide on a rear
My dilemma - I know the 12 bolt is the tried-and-true rear for f-bodies, but the stories about them really make me think twice about deciding on one. It seems like, from any vendor, that the rear has to be torn down by a competent sped shop, and double-checked on all tolerances before being installed, or one runs the risk of a fragged 12 bolt, howling gears, and the like. I realize there's probably quite a few more 12 bolts out there without any problems than faulty ones, but $3000 isn't exactly something I can afford to shell out more than once.
Since I plan on keeping ABS, I'm assuming the 9" and 8.8" are out. The 9" is also a bit heavy for my setup - I'd like to be making 460rwhp, with an M6, in a car that won't see a lot of track duty.
The other option I had been hopeful about was the S60, but again, the stories about noise problems really makes me wonder about those. I know some noise will be evident when using a gearset like 4.10s with a cut that's not designed to be the quietest out there, but I don't want to have to have my radio up all the time to drown the gear whine out. The weight difference seems minimal between the S60 and a 12 bolt, and the S60 does seem to be a lot beefier, but there's just the potential problem (almost a guaranteed problem, it seems) with gear whine on that rear end.
It's been recommended that I go with a 12 bolt for my car, but I'm trying to get opinions from as many people who have run these axcles on the street for more time than it takes to get to the track and back. Which would be the better rear to go with? Also, I'm thinking a 31 or 33 spline axle setup would be the best to go with, but terms like gun-drilled axles, and some of the other specific specs on some of the sponsor sites stymies me.
For a car that mainly sees the street, sees the 1/4 once in a while, and never sees any auto-x action (although I don't want to toss handling ability out just because I don't see organized events), what would be the best rear to go with? I know this is a question that gets asked a lot, but specifically - i.e. what spline number, standard vs drilled axles, what posi/locker, ect - I've read up and can't really come to a decision, simply because there's so much info on rears out there.
It's not like all of them end up taking a ****...you just tend to HEAR about bad ones more than you do good ones. I mean how likely are you to sign on and be like, "ohh my whisper lid is great!" Probably never. But man if that thing screwed up your car you'd be raising hell.
IMO a 12 bolt would be above and beyond what you need, considering people rock them well into the 10's and 9's. 31 spline should be fine. Hey I rhymed. All the time. Are you a mime? Found a dime.
Ok I'm done.
Ok I'm done.
Ok I'm done.
I guess the biggest question for me right now is to take the chance with an S60, have a good shop tear it down and check everything, put it back together, and hope it doesn't start whining. Depending on how well I can launch the car once I get wider tires on the back, more track passes, and nitrous might be in order for me, and the ring for the S60 just gives me more confidence that a 150 shot on top of a 450+ rwhp engine isn't going to cause carnage.
I mean really something has got to give, so you go to the track and it makes some noise afterwards, big deal. I know I don't care at least - I'm just happy to know I have a super solid rear end underneath my car. It is daily driven and it doesn't bother me.
I wouldn't bother paying someone to take apart a new rear end before at least driving it first, it may have been find from the factory. I put my Moser in and all I did was add fluid to it, it was very very quiet. Now, if you install one and it's noisy, then yeah have someone look at it...
Paid a few bucks more to have Billingsley build it out completely so I can just bolt it straight on (backing plates already installed). Amber and the whole crew up there has been great to deal with.
Again, I want to be able to take it out of the crate/box, add lube, slide on my rotors and calipers and drive.
As far as just bolting up...I'm basically doing just that - I'm going to drop the old rear and slap the new one in. Assuming you don't have a shop do the entire install for you, I think Billingsley is one of the very few places that will do the brake backing plates for you and ship the 9" ready to go. This avoids having to get plates pressed on yourself.
The only thing I will have to deal with is removing the existing ujoint from the driveshaft. It has a nylon ring that has to be melted out using a torch and from what I've read on the boards you can't use a small hand-held torch. Luckily my buddy who's helping has one handy.
I'm also throwing a new Panhard rod and LCA's while I'm under there but obviously not required.
a couple of buddies of mine checked out my new rear end and like it a lot. one of them runs a mosier 9"(4.30's) and the other a mosier 12 bolt(4.11's) and both have complained about noise and fitment with their rear ends and with their aftermarket suspension--but both have held up well for them also...except for an initial concern with the auburn heavy duty posi in the 9" that went to crap after 1500 miles of normal driving and 2 days at the track.
now i haven't had my s60 at the track yet and have only put on about 500 miles, but i haven't run into any complaints and thing is built very well.
just my .02 ...but get the strange(dana)60
more weight i get to take out
