installed 9" why the E brake light????
is that the sole reason or what else could it be.
what is the propor way to do that?
when i start the car put the e brake down teh light goes off and the Drl's come on.
drive not even 15ft and the light comes on.
should i try and readjust teh e brake of does it stay on like teh abs inop
if you have a 4 channel rear end and all your stuff works for your 9", i'm guessing you may have something unplugged along the way?
The only other thing tied into that circuit is the brake reservoir (I think). Check your fluid levels as well.
If it was a wheel speed sensor problem, that would only affect your ABS and trigger the ABS INOP light and not the BRAKE light.
its doing what ss4matt is doing.
yes i have a 3ch and i knew and read that the abs inop light would be on but i never knew about that e brake light
as you looking at the rear the 2 round rods to the left its rubbing the one could that cause some vibrations?
when im at high way speeds 60-75 and i left off the gas, in or out of gear i get some vibes from the back of the car untill i slow down to about 50 or so. drive sfaft outta balance.
but it also did it with the stock 10 bolt
