need some help with suspension
If you already have an adjustable panhard, then you can adjust it so that it does not stick out on one side. You center the rear end because it would look funny if you didn't, and because you want the car to travel as true as possible.
Also when you add aftermarket suspension - most of it is tubular, which transmits a lot more noise than you would normally hear. The torque arm especially is the culprit for a LOT of banging around, mine about drove me insane.
I doubt the bearings are worn out...after you add a bunch of aftermarket suspension, you are sacrificing quietness for rigidity. They transmit a lot more noise/clunking (especially the aftermarket torque arm).
