Quick question before i order......
Old Aug 16, 2006 | 10:07 PM
Blk97WS6's Avatar
Default Quick question before i order......
Im about to order a set of Motive 4.10s for the 10-bolt. Before i order them i have a couple quick questions.
1. I know with the richmond gears you need to either buy a paddle kit, or grind away are little from the block the holds in the c-clips for the 99+ torsen carriers, will i need to do this with Motives also?
2. Which install kit do you recommend? Richmond or Ratech? or are they basically the same thing?
thanks for the help!
Old Aug 16, 2006 | 11:01 PM
Nittany_marine's Avatar
I went with Ratech, and I was very pleased with it. Im sure a lot of other folks will say the same thing. Hope this helps!
Old Aug 16, 2006 | 11:29 PM
keliente's Avatar
Same thing.
I did not need to do any grinding on my paddle for my 4.10 motives. Good luck!
Old Aug 17, 2006 | 01:33 AM
Blk97WS6's Avatar
awesome just what i needed to know. thanks man.
I did two gear installs on my LT1 T/A
1st time i rushed it and blew up the rear
2nd time i took my time and did it right, and they were fine for 6K miles from the time i put them in till when i sold the car.
So hopefully this install goes well two.
thanks again!
Old Aug 17, 2006 | 01:54 AM
Blk97WS6's Avatar
also i came accross these
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=gm0e410|0
they are claiming that these are O.E. GM gears, packaged by Motive. are they really? because i thought our O.E. gears were produced by AAM. and if they are actually GM gears, would you go with these, or the regular Motives?
Old Aug 17, 2006 | 12:33 PM
Blk97WS6's Avatar
bump..
Old Aug 17, 2006 | 02:10 PM
keliente's Avatar
IMO it does not matter either way.
Old Aug 17, 2006 | 02:34 PM
Blk97WS6's Avatar
sounds good. thanks
