Changed my rear end fluid today.....
Old Oct 17, 2006 | 08:22 PM
02gixxersix's Avatar
Default Changed my rear end fluid today.....
I have had the car for about 3 months and finally got around to changing the tranny and rear end fluid. I was pretty pissed to see how black and crappy the fluid was and I don't think it has ever been changed. I still had what loked like the factory seal on it and lots of ltitle shavings on the magnet. No damage though from what I could see. I cleaned the **** out of it and the over and threw some Lucas 85w-140 and the additive from GM in there. Already running so much nicer. I guess I shouldn't have assumed that the car was taken great mechanical care of even though it was taken great care appearance wise.
Old Oct 17, 2006 | 09:18 PM
TransAm_00's Avatar
Happy to hear things are better. Keep it up.
Old Oct 18, 2006 | 07:16 PM
Gregg1LE's Avatar
That task is next on my list
Old Oct 20, 2006 | 08:13 AM
quiksilver9531's Avatar
yea mine too
Old Oct 26, 2006 | 01:55 PM
richnew's Avatar
Default changed rear oil what year z28?
My 2002 manual says to use sinthetic 75-90 oil and limited slip additive.
Is it o.k. to use 80-140? I just rebuilt my 2002z28 camaro rear 10 bolt.
Old Oct 26, 2006 | 02:02 PM
2000TransAmWS6's Avatar
^ 80-140 should be alright to use
people don't understand that ALL of the fluids in their car need to be changed at some point.
i just got an 03 Silverado with 118k miles on it, i've already bought the rear diff fluid, just waiting for some time that i can change it out... i bet its going to be black and smell like its burned. also i'd be willing to bet that the trasmission fluid has never been changed either
Old Oct 26, 2006 | 02:14 PM
jimmyblue's Avatar
Moderator
The service interval on the rear is not that long, but even
the dealership where I used to get maintenance ignored it.
I found much swarf in mine too. Good enough excuse to put
the T-2R, 3.42s, full moving parts / seals and a reinforcing
cover w/ drain plug.
Old Oct 31, 2006 | 06:06 AM
richnew's Avatar
Default what is a T2R ???
What is a T2R whith full moving parts and where can I get a dif cover with drain and reinforced???
Old Oct 31, 2006 | 06:36 AM
import slayer's Avatar
how often should you change the rear end fluid?
Old Oct 31, 2006 | 06:46 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Thumbs up
I own a 2001 Z28, and have been using 85W-140, GL-5 (with the GM additive) for over 6 years, with absolutly no negative effects. The heavier oil will disapate the heat from the gears faster, and at most you will loose nominal horsepower due to the thicker oil.
I am old school, so I do not use synthetic oil in my differentials.
SteveC
Old Oct 31, 2006 | 12:23 PM
jimmyblue's Avatar
Moderator
T-2R is a higher-bias, beefier Torsen chunk. I got mine from
Strano -->
Full moving parts, I mean bearings, seals, pinion spacer and so
on. If you're tearing it up, why not? Especially if the soup is
chunky style, no telling what's gotten into the bearing races.
Diff cover - I got a MAC, the TA might be better, check the
various broad-line parts sponsors. I think I got mine from New
Era if I recall. Some things about it seemed low quality (rough
casting & tapped holes, mostly) but it's OK, doesn't leak and
has the preload studs.
Old Nov 1, 2006 | 04:32 PM
anyone?
Old Nov 1, 2006 | 06:02 PM
Gregg1LE's Avatar
Originally Posted by import slayer
anyone?
Did I hear every 15,000 miles?
Old Nov 2, 2006 | 06:48 PM
joecar's Avatar
Yep, religiously.
Old Nov 3, 2006 | 02:36 PM
thanks
