TA girdle stud kit
Old Nov 12, 2006 | 07:35 PM
john563's Avatar
Default TA girdle stud kit
how much do these really help a rear (10 bolt)end? IS it worth it to get it?
Old Nov 13, 2006 | 11:51 AM
Specialized's Avatar
Id like to know as well.
Old Nov 13, 2006 | 09:29 PM
john563's Avatar
can anyone help us out?
Old Nov 13, 2006 | 09:33 PM
brad8266's Avatar
They are worth as long as you arent running slicks doing high RPM drops. It does help to strengthen the rear some.
Old Nov 13, 2006 | 09:47 PM
Krab's Avatar
From my personal experience, I'd say they aren't worth the money. This is just my personal experience though. For one thing, the cover itself does not have a magnet like the stock cover, which could collect any shavings you might have in your gear oil and possibly reduce wear. With the aftermarket cover, those shavings will be free to swim in your gear oil until you flush them out or something fails.
I've heard about them being better at dissipating heat from the gear oil, but I don't see how it can be a substantial amount. I mean, yes the cover is made out of aluminum which has a higher thermal conductivity than the stock steel one, but it is also much thicker. I haven't done any tests to prove this, this is just my assumption. They might be more effective if they had an extended surface (fins), but the ones I've seen don't have any...
One thing they do have going for them is the pre-load bolts and studs that come with the cover (if purchased). They have to be torqued to the proper loads though.
I sold my cover after I sheared some spider gears in the carrier, then just slapped my old one on. I haven't had a problem since, but then again I've also learned a few tricks on how to make the stock 10-bolt last a little longer since then. Hope this was what you were looking for.
Old Nov 14, 2006 | 06:58 AM
john563's Avatar
the reason i ask is that Im 350 350rwhp(a4)and thinking of adding n20,but just did not know how much i can push the 10 bolt.I know that it will hold more on an a4,but how much more.soft launch with the n20?
Old Nov 14, 2006 | 08:57 AM
MrDavid's Avatar
I had a buddy who put a stud and girdle kit on his SS and a few weeks later he broke the posi unit. He never launches his car, always races from a 30 roll or so. He said they didn't help him at all.
Old Nov 14, 2006 | 04:32 PM
gillbot's Avatar
They help alot imho, the rear i'm running now was broken and didn't have a girdle. After a girdle it hasn't broken again YET. That's proof enough for me.
Old Nov 14, 2006 | 05:35 PM
gillbot's Avatar
https://ls1tech.com/forums/showpost....4&postcount=42
Old Nov 14, 2006 | 07:40 PM
INMY01TA's Avatar
I don't think it's worth it to change gears in the 10 bolt at all, which you probably are if your thinking of buying the stud kit. Once you're in their, ya I'd get the stud kit.
Old Nov 14, 2006 | 08:23 PM
john563's Avatar
Im happy with my 3:23 gears just wanted to make it a little stronger cuz wil be adding more power to it soon
Old Nov 14, 2006 | 09:43 PM
ldickson's Avatar
I had a girdle on my 10 bolt and I made lots hard launches and the only think broke was the axlse.
Old Nov 15, 2006 | 04:28 PM
gillbot's Avatar
depends on how much it costs you to get it all done. I think I have less than $350 in my entirely rebuilt 10 bolt. Not a bad upgrade for my 2.73 geared car IMHO.
