Rear Abs???
The sensor on my Strange 12-bolt was recently sheared off by the reluctor wheel and since then, the ABS INOP light has been on....
Tried a panic stop in the rain, locked up and went skidding for a good 30 feet
On a side note, it is kinda nice to have for someone that does a lot of emergency braking, especially on a slick surface.
I got a shop to order me a moser rear with the reluctor rings pressed on from moser directly so they would work with the rear speed sensors (not sure if this shop specified it was an f-body or what) but the ABS has been in INOP mode since they put it in. Brake backing plates are on, rings are on, just an ABS INOP light always on. Perhaps there's a wiring/sensor issue since ABS INOP is on even at idle?
so no one has figured out how to only have front ABS huh? POOP, Well is it going to suck or will it just be alittle harder braking?
