slipping 10 bolt?
my problem is, i track mycar
when i come out of a right hander i can feel my lsd slipping.. IE the inside wheel spins alot and the outside wheel does nothing..
when taking a left hander, this doesnt happen.. so when i get out of a turn and get on the gas it bites and goes like hell
at vir this is kinda an issue cause there are alot of right handers on to long straights... in autox this sucks too because im always on the gas coming out of slow turns
if i were to change my fluid and put in some lsd addative, would this help remedy this situation?
or is this my call from god to start saving for a 12 bolt with a better lsd?
1998 ta m6 123k
under acceleration.
On a right turn the body rolls left unloading the right
tire even more. On a left turn the body roll fights the
torque reaction making more balanced wheel downforce.
A torque biasing differential like the stocker only splits
2:1 or so, max. If you have half the weight on the
right wheel (torque-lift + body roll) you're done for
friction to the road.
A higher-bias chunk, beefier sway bars and perhaps
a little lower (to cut body roll) are your prime options.
Might consider a "drag bag" to even out the weight
bias in cornering, if that's legal and you care.
ok well thats good news anyways because i just ordered SFCs and spoohn sway bars
i might change it anways just because i dont know how long its been since it was done..
on that note anyone know how important it is to change your tranny fluid in a M6? sticker on it says dextron mercron III atf fluid... is that really what goes in there? im sure a search could find this.. im just typing my thoughts
similar scheme in the True-Trac line?) all have a limit
to how much proportion of the torque can be pushed
over to the sticking wheel.
On an open diff this is 0, and all you get is spinning-
wheel acceleration.
On the stocker the bias ratio (limit) is about 2:1. So
spinning wheel is spinning wheel, but the stuck one
is given 2X that, so you accelerate 3X vs an open.
T2-R I think is something like 3.5, 4:1? So presuming
you have the grip on tire #2, you could get 5X the go.
In fact however, 4X spinning tire torque is usually
enough to break free the second as well. Not always
the case at 2:1 which is why you see people with
stock Torsens complaining about "one wheel peel" and
thinking maybe it's blown / slipping. It is, kinda, but
that's inherent to some degree. Wear and slippery
fluid can make it worse though, because the Torsen
works by binding some metal and the harder it is to
bind, the less bias. Or something.
The bias ratio can make a very large difference in the
marginal-traction acceleration you get. Power cornering
in particular is much improved with my T2-R over the
original, the outside tire gets all it can handle now.
And more.
Friction type diffs are different in how they split the
torque and how/when they give up.
been using napa gear oil 75W80 and 80W90 with the LSD additive.
mosi doent make any noise when turning or anything.
you need the GM additive with auburn.
i might try changin the fluid, who knows... it may help some.. ill just hope the sway bars and SFCs help enough to make it tolerable
